I've been pondering building a locomotive engine which runs using a stirling but using the 'foam' and heat method rather than lenses. Now this sounds impossible as I doubt you'd get enough torque. Anyone know how much torque you are likely to need to run a small locomotive? Essentially I reckon it comes down to the amount of heat difference that you can produce, so that you have the ability to drive such a thing. I know they do small cars with gamma engines, not sure what fuel they run off. But where are the limitations of using a solar energy? |
| I have only built a couple small engines. You need a small temperature differential in a lot of gas or a big differential in a little gas. The size to horsepower ratio for low temperature Stirling engines is a serious problem. How much power would be required is directly related to how fast one wants to go. My guess is that you would need a lot of collector area. The best way to find out is to try! |
| Sure, one idea I have is to use a fan and heatsink on one side for cooling. Obviously this would be solar power, just looking at the panel sizes for voltages enough to drive a small fan makes you realise everything is a little impractical. |
| stirling plans | gngh | Stirling Engines | 2 | 04-28-2011 11:15 AM |
| Bright future in solar??? New plastic solar | carbidecraters | Environmental & Alternate Energy | 13 | 04-06-2009 11:49 AM |
| Solar power | MBG | Hobby Discussion | 58 | 07-31-2008 05:19 PM |
| Steam Locomotive Plans? | nacalder | Steam Engines | 3 | 02-15-2008 07:19 AM |
| Solar Power | naytep | Environmental & Alternate Energy | 11 | 11-02-2007 01:00 PM |
