You are right, Stirlings are not IC (Internal Combustion) since the heatsource is outside the engine it selves. Neither are they to put into the category of steam engines since they don't invoke a phase change vapor <> liquid. If to be categorized I would put them among “hot air engines”, sealed devices that work trough the Carnough cycle without having the media (air, helium, whatever) to go trough a phase shift (liquid <> gas). But I guess that cnczone isn’t the right forum for this. Try Model Engineer. Best regards from Sweden, the country of the midnight sun /jan |
| Interesting read, never heard of the Stirling Engine until now, still a little confused on how it works, little too late at night for me right now... As for someone building one, I would like to give it a go, I just have to finish my 3 axis router first, oh yeah and get through the house building process, then probably a boat shed, but after that I'll get straight on it. Interesting how they make such good cooling units under outside power. Thanks for something to add to the "to do" list. Russell. |
| If you use CAD to design and CNC machines to cut the parts, why wouldn't this site be an appropriate place to discuss Stirling engine builds? Just add a new forum for threads..... Anyone interested in discussing how to make one? RipperSoftware |
| http://www.bekkoame.ne.jp/~khirata/english/make.htm heres a site for building a simple one out of a can ..... i haven;t built one yet myself the guy that got me started in the machining built one you could set it on your hand and it would run from the heat of your hand |
| A Sterling Engine is a temperature differential engine that rely's on a closed system of gas. It's motive force comes from expansion and contraction of the gas. Even though the Sterling cycle has been around for a LONG time, it's not been much more than a novelity even though there have been some very powerfull Sterlings built. Part of my leasure reading over the last year has been on producing electricity and if it was feasable for me to build something to generate power in a suburban setting. It' isn't real feasable for a DIY'er to build photovoltiac cells, I live in a region that wind isn't real practicle, so in looking for other possibilities, a Sterling engine(s) might be the most practicle for me. Utilizing the Sun's IR heating, and the earths underground 53 degree constant as temperature differential sources. Still reading and thinking though. There is a lot of interest across the world on Sterlings as an energy source. And when you consider that depending on where you live relative to the equator, on sunny days, there is nearly a kilowatt of IR energy per square meter from the sun, seems like we should be harnessing more of it to produce motive energy.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| http://www.emachineshop.com/engine/ has a simple rotary sterling
| Here's a link that shows how they work - simply two pistons, 90 degrees apart. the displacement piston alternately moves the air from a hot space to a cold one, power comes from the expansion and contraction of the air. http://www.keveney.com/Stirling.html They are low power/low efficiency and can therefor be a pain to get a model running properly. you have to hit that optimal balance of the piston sealing well enough to take advantage of the pressure changes, but have minimal drag/friction because its so low power. While low power, their advantage was that they did not the danger and complexity of steam (because there's no boiler) here's some pics of one i made, a 1/4 scale model. this particular one is water pump, using the water it pumps as the cooling force via a water jacket around the upper half of this cylinder. it runs on camp stove fuel and pumps water beautifully, but only after a lot of fine fitting and bore lapping (with homemade adjustable copper laps) |
#10
What I was thinking of was that I have seen forums and pages dedicated to Stirlings. One of my friends built one after getting hints from such a page a few years ago. Rather simple they are and some types can be built with material easily machined by simple cnc’s, materials like aluminums and plastics /jan |
#11
| jan They don't have to be simple. A NZ company is making them for generating electicity. http://www.whispergen.com/ Also one of the Scandinavian countries are using them to drive submarines. (I believe they are very hard to detect with sound equipment.) |
#12
/jan |
