Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Stirling Engines
Old 07-07-2010, 08:51 AM
Burnit0017's Avatar
Burnit0017 is on a distinguished road
High Temp Epoxy Piston Rings????
Greetings, I am starting a project using a 2 cylinder V air compressor to try to convert it to Alpha Stirling. I found some links were small projects created there own pistons using high temp epoxy. Using their idea, I am going to try to replace the piston rings with high temp epoxy and add a dry lubricant between the high temp epoxy rings Hopefully this will give a good seal and reduce friction. Has anyone tried this before? Best regards
carbon filled ptfe piston rings? samco CNCzone Club House 5 03-01-2011 07:06 PM
Looking for quotes for high temp alloys Foxwood Employment Opportunity 0 05-19-2009 11:24 AM
High Temp Tape Residue rcazwillis Mass finishing equipment/media/stratigies 3 02-03-2006 05:47 PM
spindle temp, motor temp. nervis1 General Metal Working Machines 3 07-20-2004 09:09 AM
compressor piston cylinder compared to an IC engine piston cylinder CNCnUtZ I.C. Engines 1 12-28-2003 07:06 PM
