Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-06-2010, 02:30 PM
microbeast29 is on a distinguished road
Wire stepper motors to G540
I recently purchased a G540 (very nice) and have some old Hobby CNC steppers #23-305-DS8A that I would like to use. They are 8 wire, that I turned to six wire. Which color wires go where? Anyone have a diagram to hook these up?
I know there are markings on the G540, but which colors goes to which pin? Thanks
heres the motors:
http://www.hobbycnc.com/products/stepper-motors/
ID:	99367   Click image for larger version
ID:	99368   Click image for larger version
Old 02-06-2010, 06:42 PM
rowbare is on a distinguished road
The G540 is a bi-polar drive. It takes a 4 wire connection. If you have an 8 wire motor, you will need to wire it bipolar parallel. It sounds like you have wired them unipolar. You will have to find the datasheet for the motors to see how to wire them up.
See the instructions for the G540 to wire them up to the connectors. Don't forget the current limiting resistors.
bob
Old 02-06-2010, 07:49 PM
EBC's Avatar
EBC EBC is offline
EBC is on a distinguished road
Thumbs up
This guy Mike Richards knows his stuff http://www.talkshopbot.com/forum/mes...tml?1263265394
Gene Crain
www.plantasymaderas.com
servicio de fresadora cnc
Old 02-07-2010, 12:22 AM
tumutbound's Avatar
tumutbound is on a distinguished road
From another thread (found via Search), here's the pin out for what appears to be your motor.
http://www.cnczone.com/forums/attach...6&d=1192389014
Regards
Geoff
Old 02-08-2010, 03:46 AM
MadMachines is on a distinguished road
If you have a multimeter just measure the resistance between the wires. You can work out the coils. Depending on if you join the coils or run with just 2 will decide your speed vs torque. Remember the G540 is Bipolar so you only want 4 wires connected. If you join two coils in parallel you will gain more torque. See attached diagram.
Old 02-08-2010, 04:22 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
G540 HobbyCNC wiring.
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
[IMG] code is Off
Need Help!- Wire EDM Stepper Motors Not Working sparky212 Stepper Motors and Drives 0 01-11-2010 09:20 AM
The matched G540/387ozin stepper motors are... MrWild Benchtop Machines 3 12-27-2009 10:52 AM
Need Help!- Looking Stepper Motors for G540. samsagaz DIY-CNC Router Table Machines 10 03-22-2009 04:46 PM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
How to Wire the Camtronics Stepper motors? Cold Fusion General Electronics Discussion 3 05-27-2004 02:15 PM
