Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-27-2010, 08:40 AM
marcalap is on a distinguished road
unevent motion with microstepping
HI,
I have some trouble for microstepping of a Portescap bipolar stepper linear actuator (20DAM20D1B-K) (24 step/rev). For a 1/2 microstep, the first microstep is small but the next one is much bigger. For exemple, at 1/16 microstep, there is a couple of small motions but one of the microstep will produce a lot bigger motion (~30um) . I'm using a leadshine M415B microstepper driver.
The motor pitch is 42um/step. Thus it should definitly not move more than 21 um at 1/2. A stepper with this screw pitch should be able to do below 5um per microstep. What is wrong?
Old 01-27-2010, 09:44 AM
Gold Member
Mariss Freimanis is on a distinguished road
Your problem is motor linearity. One expects a motor to divide a full-step evenly into equally spaced microsteps when it's driven by a microstepping drive. This evenness depends on the motor having good linearity. What you have is a "tin can" motor meaning it is constructed from stamped metal parts. These motors have terrible linearity; the ratio between the biggest microstep and the smallest microstep can be as bad as 5:1.
Machined motors (NEMA-17 and larger) have much better linearity. It can be under 1.1:1 for the best motors.
Mariss
Old 01-27-2010, 09:57 AM
Thanks,
This is definitly a good explaination.
[IMG] code is Off
Duda con microstepping chockstef Spanish CNCzone 3 09-15-2007 08:52 PM
Microstepping? barkster Stepper Motors and Drives 1 05-16-2007 11:27 AM
New pic for microstepping ajv2803959 Open Source Controller Boards 5 03-21-2005 11:59 PM
Lathe to CNC - Microstepping creative_mind General Electronics Discussion 8 04-12-2004 10:56 PM
Microstepping question TimW DIY-CNC Router Table Machines 2 03-29-2004 09:21 AM
