Results 1 to 4 of 4
Thread: current, decay setting question...
    May 2006
    NORWAY
    Can anybody tell me the difference between slow mid and fast decay and how it affect the speed and torque of the steppers?
    Are there any characteristics diagrams on the web which show how the voltage, current, decay, speed and torque influence each other?
    Jan 2006
    Serbia
    May 2006
    NORWAY
    Will it be possible to adjust the decay while stepper is running in order to find the smoothest option?
    And will I get a better speed if I reduce the micro step setting from 8 to 4? I have understood that this will decrease the holding torque, but I don´t think I need that much in a router where I mostly work with softer materials.
    Aug 2009
    germany
    Quote Originally Posted by jaru-eri View Post
    I don't think so.
    Most driver ICs will read the setting after .reset.
    Very likely it will simply have no effect.
    Very likely not as 1/4 and 1/8 are not much apart torque wise.
    I had some better speed effect when going from 1/4 back to 1/2.
    This might be due to the higher peak torque.
    But it was much more noisy then.
  1. Newbie- Percent Fast Decay?
    By will_eng in forum Stepper Motors and Drives
    Last Post: 11-14-2008, 01:50 AM
  2. Transfer current setting to new PC
    By CPierce18 in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2008, 09:26 PM
  3. Tool change decay.
    By ben_heinman in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 04-20-2007, 10:01 AM
  4. Drive Current Setting Question
    By electron in forum Stepper Motors and Drives
    Last Post: 03-21-2006, 08:52 PM
  5. Current question
    By Christian in forum Gecko Drives
    Last Post: 09-26-2004, 03:52 PM
