Results 1 to 3 of 3
Thread: noob question
    Nov 2009
    brazil
    noob question
    Planning on making a dtg printer but total noob soo if u people could answer
    few questions
    1 :The motors used in a paper feed mechanism of a printer are not strong enough
    for my plan can i use a more powerfull steep motor with the same specs
    ( rotation etc...)
    as the one that comes in the printer ?
    2: Can i control this motor with two diferent inputs?( one input from the printer
    and the other from another source ) they woud not be used at the same time.
    need this because the motor of the printer only goes forward and i need it to come back to the starting position to do another print.
    if possible the second input be a button that would make the motor go reverse
    mode to a certain position.
    sory for my english
    thx in advance
    Registered vger's Avatar
    Jan 2006
    I had to look up "DTG" to see what you were talking about.
    Depending on the stepper that is in the printer you are modifying, you most likely be able to find one with greater torque and the same deg/step rating. Most common is 1.8 deg/step giving you 200 steps/revolution. If you do go to a higher power motor, you may need to add an additional power circuit to drive it from the printer.
    You could put a limit switch on the moving table that would be hit when the print is done that would latch a relay (holding circuit) that would reverse the leads to the stepper putting it in reverse. Then a second limit at the home position could energize a relay to stop the movement by disconnecting the motor reversed connections on the holding relay. A time delay relay could reset the holding relay to start again. This way a "page feed" after printing would reset the table.
    Steve
    Nov 2009
    brazil
    thx
    hey steve thx a lot for ur very useful information
  1. noob question
    By epoxie in forum Benchtop Machines
    Last Post: 10-06-2009, 04:08 AM
  2. nOOb Question
    By Tazzer in forum General Metalwork Discussion
    Last Post: 07-22-2009, 08:41 PM
  3. EDM noob question
    By PDSI Mike in forum General Waterjet
    Last Post: 06-25-2009, 12:39 PM
  4. noob question
    By manufan in forum Post Processors for MC
    Last Post: 06-04-2008, 12:34 PM
  5. Noob question
    By PBfan in forum General CAM Discussion
    Last Post: 07-06-2006, 12:19 AM
