Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: POWER RATING PLEASE HELP
    Jan 2009
    I need to buy a power supply that have AC output (because my drivers requiered 80 ~ 220 VAC) but I need to know my motor power rating.
    here is my motor spec:
    2 phase bipolar
    4.2 VDC
    6.5 A/phase
    resistance 0.65 Ohm/phase
    Inductance 26 mH/phase
    Sep 2008
    Germany
    ...and what is your mains supply voltage?
    Jan 2009
    my stepper driver main supply can accept 80 ~ 220 VAC
    Aug 2008
    You don't need a power supply! If your mains voltage is outside the 80-220V range, then you need a transformer to step the voltage (presumably down) to that range.
    Your motor uses 27.5 Watts (Power=Voltage * Current) per phase, but the controller will need considerably more. It's always best to have a large safety factor: if there is only a single driver and a single motor, then I'd consider a 100W transformer minimum. If there are more drivers and/or motors, then multiply accordingly.
    Jan 2009
    I definitely need a transformer because here the source is 220 VAC and the driver max can handle is 220 VAC and I thought I could use Mariss formula which is square root of 26 * 32 = 163.16 Volt to supply the driver but I don't know how much amps to go with that 163.16 volt.
    Sep 2008
    Germany
    You obviously don't understand my question. This implies a severe lack of knowledge about electricity, particulary mains electricity, you should find an expert and let him help you before you join the Darwin awards.....
    You can't know everything, so don't get upset.....
    DKWarner is right too.
    Dec 2007
    Italy
    Hi
    Are you sure you need a transformer ?
    From your data, seems that the driver has a universal input (typically 110 to 240V +/-10%).
    If you can post some additional data (manufacturer, model, manual or link to this information) maybe some one can help you.
    regards
    Jan 2009
    The maximum Supply voltage is up to220VAC
     Output current up to 7.8A(5.57 ARMS)
    Parameters 22078
    Min Typical Max Unit
    Output current 0.42 (0.3A RMS) - 7.8 A
    Supply voltage 80 180 220 VAC
    Logic signal current 7 10 16 mA
    Pulse input frequency 0 - 400 Khz
    Isolation resistance 500 MΩ
    see the attachment for details on the stepper driver
    as you can see that the maximum allowable supply voltage is 220 VAC and in my country the main voltage is 220VAC but can be plus or minus 15% so when my main voltage higher than 220VAC I will fry my driver for sure that's one of the reason I need a step down transformer but on the other hand you can see the motor rating is most suitable when I supply it with 163 VAC according to Mariss formula. But My question how much amps or watt I will be needing at 163 VAC.
    2 phase bipolar
    4.2 VDC
    6.5 A/phase
    Attached Thumbnails Attached Thumbnails POWER RATING PLEASE HELP-22078_driver_english_manual.pdf
    Jun 2008
    What you need is ac voltage regulation. There are several manufacturers of these devices. APC is one of the best.
    http://tinyurl.com/acv-regulation
    Jan 2009
    No I don't want to feed it 220Vac but I want to feed my stepper driver 163 VAC and my question is how many watt or amps do I need for each stepper drivers if I were to give it 163 VAC?
    Dec 2007
    United Kingdom
    Just use an isolating transforma that goes from 230V to 110V AC.
    If you put 230V into this driver the motor will fry, and any AC spikes will pop the driver.
    Even at 110V the motor will still get quite hot, so really the AC voltage needs to be defined by your application, and how fast you need the motor to go.
    you can also feed in DC to the driver, because all the driver does in rectify the AC, so 220V AC would be over 300V DC onto the driver.
    If you can get 60V AC, that would be better.
    Also i would look at a 1.5KVA for three axis or 500VA for one axis.
    Quote Originally Posted by 15mgtar View Post
    Zapp Automation Ltd
    www.slidesandballscrews.com
    Feb 2007
    How about a buck / boost transformer ,( step up/ step down) one with a 24 / 48 secondary would knock 48 volts off the mains voltage. 1KVA would be more than enough for your motors. not sure if the Marris formula directly relates to this drive since it is a DC formula and your working with AC.
  • Page 1 of 2 12 LastLast
    1. Another A+ rating.
      By cephjedi in forum Automation Technology Products
      Last Post: 04-27-2007, 09:39 AM
    2. * Any idea? How to get Power Rating and RPM of stepper?
      By cjchands in forum Stepper Motors and Drives
      Last Post: 04-17-2007, 11:53 PM
    3. power supply sizing vs. servo rating
      By Erick Davidson in forum General Electronics Discussion
      Last Post: 06-06-2006, 04:08 PM
    4. Gecko power supply 2/3" current rating?
      By JFettig in forum Gecko Drives
      Last Post: 01-06-2005, 09:04 AM
    5. Is this power supply rating adequate?
      By jerryrigge in forum General Electronics Discussion
      Last Post: 11-25-2004, 11:06 AM
