Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: 1/8 step in bipolar
    Registered TigerPilot's Avatar
    Mar 2005
    Dominican Republic
    1/8 step in bipolar
    Reading through this site and other places I always see the mention of 1/2, 1/4, 1/8 steps and so on for unipolar motors but never for bipolar. Why is that. Is it not necessary because they run smother or is it because it is difficult to do, electronic wise?
    Registered Garfield2's Avatar
    Sep 2004
    http://www.fromorbit.com/projects/picstep/
    This is bipolar. Most microstepping controllers are bipolar.
    Cheers,
    Alan.
    Mar 2005
    Dominican Republic
    Quote Originally Posted by Garfield2
    Cheers,
    Alan.
    Alan
    I've emailed you, I think it's you :-), not realizing that it was you who put the link up.
    As I’ve emailed you I couldn’t find how to micro step it. Is it done though the PIC? Can you post it here instead of emailing me? Also, who made the boards for you?
    Yoram
    Sep 2004
    Quote Originally Posted by TigerPilot
    Alan
    Yoram
    I think you're misunderstanding what micro-stepping is. You don't "micro-step" it, it does it itself depending on what mode you have it set to. So for each pulse on the step line it can move either 1 full, 1/2, 1/4 or 1/8th of the mechanical step of your motor.
    The PIC is simply setting the current limit DAC's to the appropriate values for the given mode and step position. Read the datasheet for the LMD18245 if you need a better description of how they micro-step.
    I made most of the boards myself with toner-resist and etchant, but I did have some professionally made by CustomPCB.com
    Cheers,
    Alan.
    Mar 2005
    Dominican Republic
    Cheers,
    Alan.
    That was my question, how do you set the mode. I've asked since I saw the HobbyCNC board and they use jumper to control it. I know that your board is an other design so I think that it is a legit question. From your answer I gather that it is done by controlling the PIC. True?
    BTW, great board. It is so simple. I don't know why the comercial ones are so complicated. I guess that way they can charge an arm and a leg :frown:
    Thanks for the good work, Alan
    Yoram
    Gold Member MrBean's Avatar
    Oct 2003
    UK
    The jumpers on the breakout board (interface), set the step mode. There are no jumpers on the actual driver board.
    Hope that helps.
    Regards Terry.....
    Jan 2005
    Toronto, Canada
    Actually, bipolar drives are just as common.
    Mar 2005
    Dominican Republic
    Quote Originally Posted by H500
    You are right, but mostly I see here the xylotex and the hobbycnc boards mentiond. Besides, the commecial bipolar boards tend to be much more expensive. Look at Alan Garfield's site (he posted the url in a post above) and it is really simple and inexpensive bipolar driver. I'm waiting for a quote from a PCB maker and then I'll probebly order the boards and build his system.
    Yoram
    Mar 2003
    Shelby Twp, MI....USA
    Xylotex has both bipolar and unipolar boards. You can also get bare boards for bipolar drives from http://www.embeddedtronics.com
    Jan 2005
    Toronto, Canada
    One thing to note is that the hobbycnc and xylotex boards can control several motors. Also, before you select a controller, make sure it is compatible with your motors.
    Mar 2005
    Dominican Republic
    Quote Originally Posted by MrBean
    Hope that helps.
    Regards Terry.....
    Terry, I saw on your web page that you have that setup. Tell me please, how do I program the PIC? I know that there is a hex and a asm script. How do I get them to the PIC?
    Yoram
    Mar 2005
    Dominican Republic
    Quote Originally Posted by ger21
    Thanks for the headsup, Gerry. I guess I've missed it in all my googleing, :-)
    Their board is simmilar to Alan's. I saw also on that site that they have a dual axis board for US$20 including the programable chip. That might be interesting. I'll check other sites to compare prices. :-)
  • Page 1 of 2 12 LastLast
    1. Ametek motors and step down ratio
      By dowling177 in forum Servo Motors and Drives
      Last Post: 03-01-2005, 01:24 PM
    2. step angle question??
      By kywoodwrkr in forum DIY CNC Router Table Machines
      Last Post: 02-22-2005, 11:04 AM
    3. Dirction / Step lines!
      By bigal in forum TurboCNC
      Last Post: 02-06-2005, 02:51 PM
    4. Unipolar vs Bipolar
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 10-29-2004, 12:06 PM
    5. Series Bipolar and parrallel bipolar?
      By CNCadmin in forum FAQ of CNC Machine building
      Last Post: 09-08-2004, 08:17 AM
