you need a ASD36B-K (Driver) from oriental motor, go to www.orientalmotor.com and type the vexta motor number you have on the part number search, it will display the motor and the drive, price and specifications.
I have just bought a potential CNC router, it is a complete 3 axis machined that was purposed built for picking & dropping. Its very well built and looks to be reall acurate, problem is I dont know the steppers and what will drive them
X axis = Vexta ASM66AK-T7.2 DC 0.98V 2.5A axis driven by belt - Also attached is an unknown Vexta gearbox prior to drive belt pully
Y Axis = Vesta ASM66AK-T7.2 DC 0.98V 2.5A axis driven by belt - Also attached is an unknown Vexta gearbox prior to drive belt pully
Z Axis = Vesta PK266-02B DC 2A 1.8ohm drives ballscrew, also it has a Clean Damper Vexta OP8 D6CL-6.3 attached to the back of it
Its full of micro switches on all axis, they are EE-5X 671A 721M & EE-5X 674A MXOM
Do and of you guys know what I can use to drive them? Help.....Cheers
