Results 1 to 12 of 12
Thread: How much oz-in my steppers need?
    Jul 2009
    Croatia
    Hello people ,
    My first post here
    I'm building 50x30 cm work area CNC router (for PCB-s) made from MDF (1" thick)
    Here is image how it looks in prealpha version (only construction, without sliders)
    http://www.imagesforme.com/show.php/587368_IMG9144.jpg
    Get to the point..
    I'm aware that Y and Z axis motors needs to be more powerful than X axis.
    But still I don't have any ideas how much oz-inches (Nm) my steppers need to have.
    I was thinking to buy these - KL23H256-21-8B (127oz-in for unipolar drive (DIY from pminmo.com))
    But, will it do the trick? X axis will be moving only light wooden table and workpiece.
    Y axis is moving wooden piece and whole Z axis gantry (tool and stepper will be weighing approx 4 kg).. so stepper for Z axis is moving nearly 3 kilos and stepper for Y axis is moving 4-4.5 kilos.
    I'm using threaded rods from local hardware store - 14 mm diameter with 2 mm pitch. For my first CNC, i'm not looking for some extreme rapids.. I'll be happy with speeds like 200-300 mm/min.
    I hope that here is someone willing to help..
    Thanks,
    Ivan
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    It really depends on have efficent your mechanics are. 127oz should suffice with respectable efficiency.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jul 2009
    Croatia
    Quote Originally Posted by pminmo View Post
    Thanks for answer Phil (you've helped me with current chopper ).. btw what is with site (pminmo.com)? It's kinda down..
    Well.. I don't have idea how much efficient my mechanics are ..
    I know that I'm using M14 threaded rods with 2 mm pitch.. that is similar to acme 1/2-10 if I'm correct.. I'm using sliders like in drawer, because at the store did not had 20 same bearings..
    Steppers would be connected unipolar (full step), probably at 24V (9 times higher than nominal), chopped;
    I'm student, so i don't want to spend 150$ and see that motors are weak..
    TIA..
    (EDIT: site works, it's DNS problem)
    Jun 2003
    St. Peters, Mo USA
    Quote Originally Posted by Ivan.Kalafatic View Post
    TIA..
    DNS on your end? As I've not noticed anything.
    Jul 2009
    Croatia
    Yup.. sorry for false alarm..
    Jul 2009
    Croatia
    Uhm.. I know that patience is virtue.. But anyone has other opinions? I appreciate pminmo's answer, Phil is experienced machinist, but I want second thought..
    TIA..
    Jun 2003
    St. Peters, Mo USA
    BTW, the bipolar half coil and unipolar rating of the motor in this video is 126 ozin:
    http://pminmo.com/which-stepper-motor
    Jul 2009
    Croatia
    Yeah.. i've seen that video already.. Very nice job.. Can you tell me how much weights drill and Z construction (what is load of Y axis.. at least approx)
    thanks..
    Jun 2003
    St. Peters, Mo USA
    spindle an z together probably 4 lbs
    Jul 2009
    Croatia
    Pretty easy.. I have noname-made-in-china "600W" drill (costs 23$) that has 4lbs itself.. and 1.5 pound on stepper.. pound on wood/rest of construction.. 6.5 pounds.. I hope that 127 oz-inches will be enough.. If not, 185 should be enough (new bipolar drive)
    Thanks again Phil
    Jun 2003
    St. Peters, Mo USA
    You have a lot of mechanical advantage so for the rapid speeds you described in your 1st post, you shouldn't have an issue. You can always go larger without much of an issue.
    Jul 2009
    Croatia
    I guess then that i'll be ordering steppers from 1st post this week or so.... Again, Phil, thank you so much!.. And yeah, Tachus42 chopper is working.. despite few burned fets )
    1. Hot Steppers
      By Xnaron in forum Gecko Drives
      Last Post: 04-23-2009, 09:25 PM
    2. What about these steppers?
      By blfinche in forum DIY CNC Router Table Machines
      Last Post: 08-25-2006, 01:56 PM
    3. Two steppers on one 201???
      By Greolt in forum Gecko Drives
      Last Post: 06-13-2006, 07:37 AM
    4. Are all steppers DC?
      By DennisCNC in forum Stepper Motors and Drives
      Last Post: 06-09-2006, 09:28 PM
    5. Why Not Use Steppers
      By Steve Etter in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 12-20-2003, 11:04 AM
