Results 1 to 2 of 2
Thread: 3 axis unipolar motor driver board
    Banned serkanozfe's Avatar
    Oct 2004
    CNC3AX card drives 3 unipolar motors directly from PC parallel port interface.
    This card is software compatible with several applications such as Guillaume COQUERY's CNCFRAISE.
    Motor types are unipolar, 40V, 5A per phase maximum. Do not forget to stick the MOSFET on an aluminium heat dissipator (over 2A/phase only).
    http://www.techlf.com/cnc3ax-eng.php3
    Attached Thumbnails Attached Thumbnails 3 axis unipolar motor driver board-cnc3ax.gif
    Oct 2004
    and 4 axis control board
    CNC8AM card drives PAP8ABM cards (microstep and servo) through RS232 serial port. Up to four axis cards can be connected, which allows you to drive any choice of unipolar, bipolar or servo motors with optical encoder.
    Two 250V/10A power relays can switchon/off any kind of spindle or vaccum system.
    The card provides 8 digital inputs including end switches and 5 digital outputs.
    More functions have been added to PRO version:
    - code optimisation, up to 50 000 pulses/sec
    - spindle rotation speed control (PWM) for PROXON FBS12/E or 220V spindle
    - 4D linear interpolation (4 axes)
    - 2D circular interpolation
    - arc of circle and full circle algorithms
    - ring buffer for constant speed paths
    - real-time speed override
    - temperature feedback
    - buzzer for error alarms
    - power output 2 relay 250V/10A
    - 5 more digital outputs
    - 8 digital inputs including end switches
    http://www.techlf.com/cnc8am-eng.php3
    Attached Thumbnails Attached Thumbnails 3 axis unipolar motor driver board-cnc8am.jpg
  1. Hypothetical 1 axis 3977 board
    By pminmo in forum Open Source Controller Boards
    Last Post: 04-14-2005, 04:41 PM
  2. 4 axis control board question
    By cnctoolman in forum Hobbycnc (Products)
    Last Post: 04-01-2005, 04:30 PM
  3. HobbyCNC 3 axis controller board review
    By CNCadmin in forum Hobbycnc (Products)
    Last Post: 02-10-2005, 05:43 PM
  4. Trying to clarify, for newbie as me. Comments pls
    By pigifly in forum Open Source Controller Boards
    Last Post: 10-04-2004, 03:23 PM
  5. Troubleshooting the OS discrete single axis board
    By Konstantin in forum Open Source Controller Boards
    Last Post: 08-24-2004, 05:31 PM
