Page 11 of 21 FirstFirst ... 891011121314 ... LastLast
Results 121 to 132 of 243
Thread: 4 Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question
  1. #121
    Apr 2009
    ISRAEL
    5 axis cad model
    Shalom Friends,
    I made a 3d CAD model of 5 axis board and I would like to let it be my small contribution to all of you. You are free to use it as you wish.
    Wish Best of luck for all of us
    Vlad
    Attached Thumbnails Attached Thumbnails 4 Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question-.jpg   4 Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question-b.jpg   4 Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question-c.jpg
    Attached Files Attached Files
  2. #122
    Jun 2009
    germany
    Wow, hot images..
    Scanned with 3d-Scanner?
  3. #123
    Apr 2009
    ISRAEL
    Not a all. I made it in solidworks, that way it's easyer to me to configure my mashine layout. If any one need I can publish a power supply model to.
  4. #124
    *Registered User*
    May 2009
    Quote Originally Posted by zeed View Post
    hello,since my cnc project is comming to the end I am planing to buy one of this boards(I guess they beat my L297-8 DIY vesion) ,can you recommend one ebay seller?
    univeloptech?
    Iwannabuy?
    easysupply?
    yourschoices?
    Just too many of them
    If i got this right the boards can only give 1,5A and not 2.5A as they say?
    And to all of you who have this board working can you share your expirience with them?
    Read the post here carefully and dont buy any Chinese board unless you are good in electronics.
  • #125
    *Registered User*
    May 2009
    Quote Originally Posted by ghostshells View Post
    That's a nice work man, thanks for sharing
  • #126
    Jul 2009
    Finland
    I think my platform is not working because of the LTP-port on my laptop... I connected a led directly to ports all over the connector and It did not blink at all. It was just on all the time. What do you think is this the problem or should the blinking be so fast you dont notice it at all ?
    Is there a easy way to test LPT-port?
  • #127
    May 2009
    Holland
    Quote Originally Posted by Jur1 View Post
    My 8435 board has 5 LEDs that blink when a signal is present. Well... I can't se a real blink, what I see is the LED fading in and out as the stepper accelerates and decelerates. So I suppose you that, as long as your LEDs are coupled in the right way, you would see them glowing as the train of pulses come up.
  • #128
    Apr 2009
    Croatia
    Quote Originally Posted by kolias View Post
    well,electronics are not such a problem,I have two options:
    1:Make 2 more diy halfstep l297-8 from pminmo site (already sucesfuly builded one for testing purposes)
    2:Buy one of these chinese drivers
    I am working on very limited budget so these are my only options
  • #129
    Jun 2009
    germany
    Perhabs a parallel Printer?
    ..try to set the parallel-Port to ecp / epp in notebook bios, perhabs this helps.
    What's with the led's on the cnc board, is the any reaction if its attach to your notebook?
    Can you identify your LTP-Port in hardware-manager and when with what parameters?
  • #130
    May 2009
    Holland
    Fair enough. All is a matter of measuring how much your time is worth. If you have time in your hands and not much money (been there...) here is my advice:
    1-Get the 8435 datasheet and read it over again until you know really well how the chip works. When you know that, the Chinese board will be pretty obvious to you as it is just a wrap over the chips.
    2- Read this thread in detail. There is a lot you can learn. Then read everything else you can find about steppers and understand the electronics involved.
    3- Define exactly what you need in terms of current, voltage, stepper model etc... In the end of the day this will translate to your torque and maximum speed (you do know the requirements for the work you have in mind right? Else just go back to the drawing board). I think this is the deepest problem with people getting into CNC control or even robotics in general: they don’t even know what exactly they want to achieve.
    And that is pretty much it. If you have time in your hands, even with not much money you can do great things. All you need is patience to study and discernment to know when you are ready to wire it up and press the power switch.
  • #131
    Jul 2009
    Turkey
    Hello everyone. I need a little help here.
    Here's my status: I got my 1,5 A unipolar 6 wire steppers; 4 of them. I got the Chinese 4 Axis board from Ebay. (Kolias' board: HK1
    I measured the resistance between all the wires and figured these out about the motors:
    For Phase 1 of the stepper:
    Blue and Yellow Wires: coil ends
    White Wire: common
    For Phase 2 of the stepper:
    Yellow and Red Wires: coil ends
    Black Wire: common
    Now, can you help me and tell me where to connect all these wires on the board?
    I got A+, A-, B+, B- for all four axeses on the board; X, Y, Z, C.
    And there're M+, GND, M- connections at one end of the board connections.
    Thanks so far, I've already learned much from this thread.
    Peace
  • #132
    Jul 2009
    UK
    The motors can be connected in a couple of different ways, but easiest would be as follows
    A+ Blue, A- Red. B+Yelow B-Red Insulate the 2 black common wires.
    You can connect for parallel, but for this you should identify the pairs of coils you will use as you will only use one half of each winding i.e. the black wires will be A+ and B+ and either the Red or Blue will be the A- and either the Red or Yellow will be the B-
    If the motor turns in the wrong direction you can reverse it by changing one set of wires for example A+ to A- ,A-to A+. Only change one pair. Most software gives you the ability to reverse motor direction in the setting up.
    Hope this helps
  • Page 11 of 21 FirstFirst ... 891011121314 ... LastLast
    1. Mach 3 interface to stepper motor driver
      By dhookings in forum Machines running Mach Software
      Last Post: 06-11-2009, 05:11 AM
    2. Newbie- Stepper motor A vs driver board A
      By tsknutsen in forum Stepper Motors and Drives
      Last Post: 03-13-2009, 09:41 PM
    3. Need help to locate stepper motor control board plus driver
      By Techbuilder in forum DeskCNC Controller Board
      Last Post: 10-14-2008, 08:11 AM
    4. 3 axis stepper motor controller board - question
      By Yellowbeard in forum Stepper Motors and Drives
      Last Post: 04-06-2005, 11:02 PM
