Results 1 to 5 of 5
Thread: old MAE & Sanyo Denki stepper motors
    Aug 2007
    Romania
    Hello everybody ,
    I need some information about following step by step motors :
    1. MAE HY200 2226 0470 ACM8
    2. MAE HY200 2220 0100 ARM8
    3. Sanyo Denki Step Sin 103-770-3251
    I have tried on Google , but with no significants results.
    Registered vintageracer's Avatar
    Apr 2008
    You can find info on MAE steppers here;
    http://www.ametektip.com/index.php?o...article&id=169
    Timothy
    Dec 2008
    I found this at http://sanyo-denki-online.com/
    Our simplified stock numbering system identifies each motor instantly. As an example, here is our Nema Size 34, 720 oz/in., 6 amp, single shaft, bi-polar motor. Here's how it works.
    Example for stock # 346-720-SB
    The first two digits indicate the Nema or Metric frame size.
    The third digit(s) indicates the motor's amperage.
    720= Ounce inches of holding torque rounded off.
    S or D =Single Shaft or D=Double Shaft
    U or B=Bi-polar four wire or U=Uni-polar six wire
    Cheers
    Baxy
    Registered SteveS's Avatar
    Oct 2004
    step-syn question
    moving this reply to new thread
    Jul 2008
    Found info on Step-Syn 103-770. Hope it's helpful.
    http://www.rta-deutschland.de/pdf/103-770.pdf
    1. Step-Syn Stepping Motors Sanyo Denki
      By Shanghyd in forum Stepper Motors and Drives
      Last Post: 01-16-2011, 12:47 PM
    2. how many rpm to expect from sanyo denki stepper ?
      By mladanmar in forum DIY CNC Router Table Machines
      Last Post: 12-24-2008, 10:48 PM
    3. Need help with Sanyo Denki stepper
      By vova in forum Stepper Motors and Drives
      Last Post: 05-20-2008, 12:16 PM
    4. HELP !! Sanyo Denki stepper motors ??? what are these ones ??
      By FPV_GTp in forum Stepper Motors and Drives
      Last Post: 03-22-2007, 12:46 AM
    5. Sanyo- Denki Step Syn motors need some help on driver for
      By rollin_ballz1 in forum DIY CNC Router Table Machines
      Last Post: 03-07-2006, 09:21 AM
