Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Nema 23 stepper motors
    Feb 2008
    England
    I have 3 x Nema 23 high torque motors (3nm), they are barely 2 months old and have been running on a lower voltage & current that what they need.
    The motors worked perfectly fine for 10mins, I then turned them off and came back to them 3 days later and now will not turn and just vibrate (regardless of what I do with Mach 3 motor tuning).
    They seem to be vibrating at different levels, 1 is very weak but another is very strong, they just don't turn and make loud noises while moving around the bench.
    Could they be broke, or is there another explanation?
    Thanks in advance.
    Registered jeffs555's Avatar
    Jun 2004
    I doubt it is the motors. The probability of all 3 motors failing at the same time seems rather low. More likely is something common to all, like the power supply or drive. Also check for broken connections like a common ground somewhere.
    Apr 2008
    do u have decent drivers for the steppers? maybe you just don't have enough power?
    Sep 2007
    disconnect 2 and see if 1 will work on the PS you have.
    Feb 2008
    England
    I've disconnected 2 of the motors but it hasn't made a noticable difference.
    When I have the motors connected it seems like it wants to turn, it moves about 2 or 3 steps each way but will then not move until I change the direction I want it to move and then it moves a back to where it started.
    They were all working perfectly fine a few days ago, moved everything really well.
    Registered LeeWay's Avatar
    Jun 2004
    It could be that you have loaded a different profile in Mach. I have done this before and things were really weird until I figured out what I had done.
    Set you acceleration really low and try. If that don't work, try swapping the active high or low settings.
    Lee
    Feb 2008
    England
    I've checked all the settings on Mach 3, checked all the current & amp settings on the Stepper Driver and everything is set as it was before when they worked.
    Its so weird, you wouldn't believe everything that has went wrong with me setting the machine up, its like someone is trying to tell me something.
    Apr 2007
    I guess there are 2 paths
    - Self diagnosis
    - Vendor diagnosis
    To get help on a forum, you will need to describe each and every part, setting, wiring diagram, etc. It also assumes you have some tools to visualize electrical outputs - like an O scope.
    If you are missing these (like many of us), then it might be useful to see if there is someone you can send some of the parts to so that their individual performance can be tested.
    Example - maybe another forum member can test your motors on their system ? OR - send at least 1 back to the supplier and see what they thik. Same with the other parts.
    I would certainly take all of the load off of the motors (take them off the machine) to see if that helps.
    Check your grounding paths. Use braided cable and make sure something is not floating up the ground connections.
    Jun 2004
    It really does sound like electrical or a setting issue.
    I would think if the drives went bad, you would not have any motion. Electrical noise could surely do this as well.
    Is there anything located near the controls that wasn't there before?
    Do a Control Alt Delete and check to see what all is using resources on your PC.
    Lee
    Feb 2008
    England
    The motors haven't been attached to the machine throughout the tests.
    I attached some old motors to the driver board and they worked fine, unfortunately they aren't powerful enough to move the machine.
    The motors I have are these ones
    The Driver board I have is this one
    I am supplying the board with 13.8v & 7amps, I know thats very low but its the best powersupply I could afford and find that was UK wired.
    I have the motors wired in series, I have sat for hours with 1 motor and tried a lot of different settings on Mach 3.
    I'm pretty much an amature at this, how would I check the ground connections?
    Thank you all for your replies, its greatly appreciated.
    Registered Kipper's Avatar
    Jul 2006
    England
    Quote Originally Posted by nenetwork View Post
    13.8V is V low.....24V would be a start.
    Keith
    Dec 2007
    United Kingdom
    Is the power supply regulated or unregulated? 13.8V is very border line, and the line voltage may have dropped and causing the driver not to start properly.
    The 12V min voltage will most likely have a +/-10% tolerance?
    As kipper said, try another power supply, with a min voltage of 24V DC.
    Zapp Automation Ltd
    www.slidesandballscrews.com
  • Page 1 of 2 12 LastLast
    1. nema motors
      By radex in forum General Electronics Discussion
      Last Post: 07-23-2008, 12:22 AM
    2. Newbie- Nema 23 Servo Motors
      By numb-lock in forum Want To Buy...Need help!
      Last Post: 05-20-2008, 06:33 PM
    3. Looking for NEMA 17 high torque stepper motors
      By eljainc in forum Stepper Motors and Drives
      Last Post: 12-11-2007, 01:53 PM
    4. Encoders for Nema 23 Stepper motors
      By jfc11 in forum DIY CNC Router Table Machines
      Last Post: 06-22-2007, 12:14 AM
