Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-29-2004, 03:12 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Not good for a stepper motor?
I have a bipolar stepper motor. Sometimes I shut off the power to my power supply in order to do some manual machining. The only problem is there still seems to be, what I believe, is electricity in the stepper motor and this causes cogging and resistance if I try to turn the stepper by hand at any fast or even descent speed. I guess this is what is meant by powering down the stepper. Anyway, does forcing the motor to turn with cogging and resistance hurt a stepper motor in any way? How can I power down the motor before turning manualy?
Old 11-29-2004, 03:20 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
You are using the stepper as a generator. This won't hurt the motor at all. It could potentially hurt your drive if you turn the motor really fast and have way of dumping the back EMF back to the PSU.
You would have to disconnect at least one lead wire per phase. The motor would still exhibit some cogging though.
Regards,
Mark
www.wrathall.com
Old 11-29-2004, 10:39 PM
swarfmacdaddy is on a distinguished road
What type of drives are you using? I have Gecko g201s and didnt have the funds to finish my cnc for awhile, and kept the motors hooked up to the drives while cranking on the handwheels real fast and ended up blowing the opto to one of them. Now i have the disable hooked up like i should have. Its also takes alot less effort to do manual turns. Especially with 580 ounce inch motors.
Old 11-30-2004, 08:25 AM
FLUTE HEAD's Avatar
Gold Member
"Now i have the disable hooked up like i should have"
Randy, I'm using the xylotex 3 axis board. Could you or someone guide me onto how I can hook-up a disable. From what I gather, I guess I need to "drain" the electricity from my motors so they will be easy to turn. Is there a quick and easy solution? thanks
Old 12-02-2004, 12:31 AM
Flute, Sorry to take so long to get back to you but i havent checked me email for a while. If you go to the Xylotex website look for the pdf file entitled preliminary 3 axis datasheet, and on page 6 of 8 under the heading of ENA# inputs it gives pretty clear instructions on how to hook up the disable function. It also gives alot of warnings about back EMF voltage to the drives. Hoped this helped.
[IMG] code is Off
looking for good price on 400 oz-in or bigger stepper motor mike10 Stepper Motors and Drives 9 07-17-2008 01:13 AM
Stepper Motor Selection dberndt Stepper Motors and Drives 7 12-06-2004 07:50 AM
Is this a Good Stepper Motor Biggermens Stepper Motors and Drives 5 11-03-2004 06:57 PM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 06:58 AM
Motor selection advise needed? Servo or Stepper Beezer DIY-CNC Router Table Machines 1 03-21-2004 01:24 PM
