Results 1 to 4 of 4
Thread: Stepper moter sizing and power requirements
    Oct 2008
    UK
    Hello, Im design a CNC router for a college project, but im getting a bit stuck with the calculations.
    I've done an experiment to try and calculate the force required to cut a groove though a sheet of MDF at a depth of 6mm with a woodworking router, this showed that with a mass of 8kg attached to the router with a piece of string would pull the router at said depth at a rate of 0.02m/s.
    So, the question is, how can I use this information to calculate the power required to move that router in watts, instead of kg. And then use that to calculate the stepp
    I'd really appreciate any information you can give me on this, I'm really struggling to get my head around it.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Mar 2003
    Shelby Twp, MI....USA
    Jul 2008
    UK
    Specific cutting force of MDF is approx 6 N/mm^2. The force you applied is 8kg = 80N (approximating gravity to 10 and ignoring friction) with a 6mm DOC, so this suggests a 2mm diameter cutter which sounds small... what size cutter was it?
    However the way to calculate required torque is shown below:
    The required motor torque to drive a leadscrew assembly is the sum of three components: static friction torque, torque to resist the cutting forces and inertial torque, T = Tf + Tc + Ta
    - Tf: Torque to move load against friction: The torque to move a certain load is a function of the lead and efficiency of the leadscrew assembly plus the friction of the linear bearings
    Tf = Load x Lead x u/(2π x e) Nm
    where:
    Load = N e.g. mass of gantry x 10 (for gravity)
    Lead = metres
    u = friction coeff (oilite bearings is roughly 0.3-0.5, linear/ball bearings is 0.1)
    e = efficiency of screw (0.8 for ball, 0.2 for acme or trapezoidal)
    - Tc: Torque to resist cutting forces
    Tc = CF x Lead/(2π x e) Nm
    where:
    CF = cutting force in N (this is your 80N)
    Lead = metres
    - Ta: Inertial torque:
    Ta = (ls + IL + Im) x α Nm
    where:
    Is = The inertia of the screw in kgm^2 = π/32*density * length * diameter^4
    (density in Kg/m^3 = 7850 for steel, length and diameter in metres)
    IL = effective inertia of load (kgm^2) = Load x (Lead/(2π x e))^2
    Im = motor rotor inertia in kgm^2 (typically 2 - 5 x 10^-5kgm^2)
    and
    α = Angular acceleration (rad/s^2)
    A typical acceleration for a small to medium machine is 2000rad/s^2 which allows it to follow a cutting path without under or overshoot.
    Note: if geared/belt reduction (i.e. not 1:1 drive) then:
    (Tc + Tf) is adjusted by the ratio
    (Is + Il) is adjusted by the square of the ratio
    Additional torque associated with driving and supporting the leadscrew must also be considered but can generally be accounted for by adding 5% assuming supporting ballraces and good quality couplers.
    These torques are at the operating speed of the motor, not the holding torque. So once you have worked the torque T out you must work out the actual motor revs at the required cutting speed (depends on lead) and from the torque curves factor this back to the required holding torque (or use the fact that typically torque at cutting speed = 40% holding torque)
    A working margin of 1.5 - 2 times is considered normal (so if 1Nm is the result of the above a 2Nm stepper would be selected)
  1. Newbie- Stepper power requirements
    By stevestk in forum Stepper Motors and Drives
    Last Post: 05-18-2008, 07:33 AM
  2. Stepper Motor Power Requirements
    By GAWnCA in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2007, 02:44 PM
  3. 2010 power requirements?
    By Splint in forum Servo Drives
    Last Post: 06-26-2005, 09:21 AM
  4. Power Requirements
    By CapnC in forum General Electronics Discussion
    Last Post: 12-29-2004, 11:39 AM
  5. hpgl and stepper moter control
    By Jan in forum General CAM Discussion
    Last Post: 01-08-2004, 01:00 PM
