Based on the spec sheet for my Keling 425 oz. 8 wire steppers, it looks like you need to reduce the amps by 20-25%
If you set the amps a bit low, the motors will not produce as much power as they could. If you set the amps too high, the motors will get hotter than they should.
John
LinkBack URL
About LinkBacks
