Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-22-2004, 01:57 PM
FlyElectric is on a distinguished road
Stepperworld SP-3/HT wiring question(easy one)
Hi, I've been lurking on here forever and have finally ordered a setup from stepperworld and have all the parts cut for the machine just waiting to be assembled. My (stupid) question is how exactly am I supposed to hook up the motor wires to the board (I'm using the resistors that came with the kit) the schematic makes sense to me but I just want to make sure I do it right, I don't want to fry the board. It looks to me like you would have to solder the black and white wires to the others but a friend of mine says no that all I have to do is connect the black and white to the resistor and then the the board (he says the black and white are already connected inside the motor and the "loop' symbol is actually the motor) PLEASE HELP, I know this is a dumb question and I'm pretty embarrassed as it is! FILE IS ATTACHED!
Scott
Old 11-22-2004, 01:59 PM
The red stripe wire somehow got messed up in the transmission but it looks exactly like the green side in reality.
Old 11-22-2004, 06:50 PM
Chagrin is on a distinguished road
Your friend is correct. Twist the black and white together and then attach to the resistor, and then the other end of the resistor to the board.
The diagram you have is demonstrating the connections inside the stepper motor. If you take the time to sit down with your motor and use a multimeter to experiment with the current connecting paths (noting their resistances) between the seperate wires then that diagram will make a little more sense.
Old 11-22-2004, 08:56 PM
Thank you very much Chagrin! Shouldn't be long now, just got the last part of my machine in today (a Z-axis assembly, got it off of ebay....looks pretty neat though) I think I'm going to buy a book on basic electronics, it's something I've always wanted to learn anyway.
Thanks again!
Scott
Old 11-23-2004, 09:57 AM
ccm ccm is offline
ccm is on a distinguished road
I've got almost the same board, but with the high output transistors the FET3 and I didn't even think of connecting up my motors that way.... Plus another mistake I believe I made which I realized last night was that I had the Current limting Resistor on the XY + to the board, not on the output to the motor... So that could have been why the motors stalled so easily.
So inadvertantly.... thanks Flyelectric and Chagrin....
I'll have to post pictures of my setup on the HF mill.
-Art
Old 11-23-2004, 01:27 PM
Glad my question helped you out! I will post a pic here also just as soon as I get it screwed together and painted! Here's a link to that z-axis assembly I bought on ebay, the rest of my machine is all MDF and drawer slides (the really good ones though) Hey CCM, I see you are right down the road from me in MA!
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
Old 04-16-2005, 01:48 PM
happytriger2000's Avatar
happytriger2000 is on a distinguished road
hi, can anyone tell me the purpose of the terminal circledin yellow, and the dip switches on the board?
thx
CS chang
Old 04-17-2005, 12:43 AM
Well one side is for your power (from your power supply) and the other is for a switch (I think), I will have to take a look at mine and see which side is which and I'll get back to you.......although it should be clearly labeled as such on the schematics you have, I haven't looked at them in such a long time myself though.
Scott
Old 04-17-2005, 07:07 AM
Thanks Flyelectric,
When you bought your controller, did it come with any manual?, when i received the box, there wasnt any schematics or instructions on wirings only a piece of black and white picture of the controller board, Do you think you can post a picture of your controller's wirings??. it will really help me...
I want my controller board to be used for milling and drilling PCB board,Can you sufggest any softwares to go with the controller?
thanks again
cs chang
[IMG] code is Off
Wiring help. dmgdesigns General Electronics Discussion 3 04-17-2005 12:12 AM
Wiring Question The Wizard General Electronics Discussion 17 01-04-2005 01:11 PM
Xylotex vs. Stepperworld? kayakman General Electronics Discussion 27 10-20-2004 02:16 PM
Wiring of RS 232 Cable Niall Machine Problems, Solutions , Wireless DNC, serial port 6 03-23-2004 04:36 AM
Wiring diagram for single phase T-813 Transformer to VMC 4020 Fudd Fadal 11 03-07-2004 10:28 PM
