| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hey guys, I was messing with my new and old steppers, My new ones are rated at 4.3v and my old ones are around 2.37v I think if I remember correctly. I hooked them up to the same voltage and amperage and I can get higher speeds out of the 2.37v motors, I know this is because of the voltage is multiplied many times more. If I were to double the voltage of my power supply, would I get about or possibly more torque out of the higher voltage steppers? I dont have my older steppers off my mill, but I can rapid at 60ipm or 10000hz, and if I try that at the same voltage on the new steppers it misses steps easily. I still can give the new steppers almost another amp of current so I know that will help. But I am thinking about order another 2 transformers to increase the voltage 2x(need two because of the size of the one I have in mind) Its been a while cince I have looked at the gecko manual, I think there is a little info in there about it. Jon |
| Speed is proportional to voltage. Double the voltage and double the speed. With all things being equal. Are the 2 different motors the same torque?
| Hello, Your holding Touque rating (ie. oz/in Rating) is based on per amp. So going from 2.3 to 4.3 will just short of Double your Torque rating, provided your board and power supply are up to the challenge. Glen |
| Glen, he's talking volts, not amps. But yes, amps are proportional to torque, as long as you don't exceed the motors rated torque.
| The step-syn motors are slightly larger, they will take about half an amp more, the voltage is just higher. I dont know what the specs are on the step-syn motors though, I got a few comming though ![]() but so basicly the speed is dependant on the voltage multiplied by the motor voltage. This is what I was pretty sure of, I just wanted to make sure and all. Thanks Jon |
| High Speed Hard Milling | MachineSMM | Hard and High Speed Machining | 24 | 03-27-2006 07:31 PM |
| Stepper Motor High Torque Low Amp | Sanghera | Stepper Motors and Drives | 13 | 03-21-2005 07:16 PM |
| Motor calculations | jevs | General Electronics Discussion | 25 | 03-21-2005 02:05 PM |
| High Speed Spreadsheet | MachineSMM | Hard and High Speed Machining | 15 | 07-20-2004 05:41 PM |
| Steppers - High or Standard torque | drakesis | General Metal Working Machines | 1 | 06-23-2004 08:52 PM |
