Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-02-2004, 11:14 PM
Biggermens is on a distinguished road
Is this a Good Stepper Motor
Is the Pacific Scientific K31HXLJ-LXK-NS-00 a good stepper for a Gantry Style CNC wood router about 9 feet long 5 feet wide and the Z axe 12" tall ???
I am using a acme screw 1/2 inch with 8 turns per inch
THanks
Old 11-03-2004, 12:44 AM
Moondog is on a distinguished road
[QUOTE=Biggermens]Is the Pacific Scientific K31HXLJ-LXK-NS-00 a good stepper for a Gantry Style CNC wood router about 9 feet long 5 feet wide and the Z axe 12" tall ???
What are the motors specs. What Axis are you wanting to drive.. All?...
I assume your 1/2 inch Acme is for the y and/or Z... If not you may consider at least 1 inch or above for the X axis drive.
The size of the motor depends a lots on your setup. Ball screws, Linear bearings and the cutting you will be doing. For a large router I would think you'll need at least 800 oz.in for the X & Y and smaller for the Z.
Old 11-03-2004, 03:48 PM
The motors are 805oz-in, 1.4A, 6.21ohms, 40.7mH
i am using them for all axis and the 1/2 inch acme is for all axis
Old 11-03-2004, 04:09 PM
ger21's Avatar
Ideally, you'd want much higher amperage motors. Also, the higher inductance will limit your top speed. Those art 8.6V, you'd probably like to be in the 2V to 5V range. What kind of drivers are you using?
The 1/2" acme is not a good choice for much over 4ft. It's just not strong enough, and it will probably whip badly at any decent rpm. A much better choice for that size machine might be rack and pinion.
Old 11-03-2004, 06:56 PM
rack and pinion? what is that how dos that work ?
Old 11-03-2004, 06:57 PM
that is the wrong part number for the motor K31HRLh-LNK-NS-00
My mistake
sorry
[IMG] code is Off
looking for good price on 400 oz-in or bigger stepper motor mike10 Stepper Motors and Drives 9 07-17-2008 01:13 AM
Stepper Motor Selection dberndt Stepper Motors and Drives 7 12-06-2004 07:50 AM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-02-2004 12:31 AM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 06:58 AM
Motor selection advise needed? Servo or Stepper Beezer DIY-CNC Router Table Machines 1 03-21-2004 01:24 PM
