Results 1 to 3 of 3
Thread: Shielded cable for stepmotors?
    Jan 2006
    Finland
    Do I need to use shielded cable for stepmotor use? Cables are going to be 2 meters long / each. Is 4x0,75mm2 cable enough for max. 3,5A?
    Dec 2005
    UK
    Quote Originally Posted by mkuivamaki View Post
    Dear mkuivamaki,
    It is a very good idea to use screened cable because it helps reduce electrical interference on other parts of the control circuits. Only ground the screen at one end, not both.
    If your cable has four conductors each of 0.75 mm2, it should be OK up to 6 amps, and the voltage drop down a two metre length of cable is not going to be an issue.
    Best wishes,
    Martin
    Jan 2006
    Finland
    Thanks a lot Martin!
  1. Shielded versus not shielded cable.....?
    By REVCAM_Bob in forum General Electronics Discussion
    Last Post: 05-23-2007, 08:55 AM
  2. Shielded cable help please.
    By Oldmanandhistoy in forum General Electronics Discussion
    Last Post: 04-02-2007, 08:05 AM
  3. Source for shielded cable?
    By Alex_Cole in forum Servo Motors and Drives
    Last Post: 03-25-2007, 12:16 PM
  4. Shielded Cable
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 06-13-2006, 11:00 PM
  5. six conductor shielded cable
    By stirlingnut in forum General Electronics Discussion
    Last Post: 01-23-2006, 06:53 PM
