Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 10-25-2004, 10:30 AM
ragrillo is on a distinguished road
Help to manage L297/L298 chips
Hi to all
I am a new user of stepper motors (bipolar) and I am trying to work with the L297 controller and the L298 driver. I am setting the the L297 in the two phases on mode.
The circuit I am ussing is the recommended in the Application Notes of SGS - Thompson.
I was able to manage the L297. It means I had get the outputs I was expecting from the controller, (in pines Inh1, Inh2, A, B, C and D while I move the clock manually) but I did not get the necessary voltage in the winding pins (2 - 3 and 13 - 14 of the L298).
The voltage I get between the ends of the same coil were, different of zero, but similiar between them, that means that never circulate any current through the windings.
As I place Control in High level, for Phase chopping, I thought the problem could be in the sensing current circuit. To avoid that problem, I connected the pins 13 and 14 of the L297 to Gnd and a pair of 14 ohms resistences instead of the windings and 20 Volts to the Supply Voltage (Pin 4 of L298), to be sure the curent wasn´t never higher than 2 A, but nothing change.
I had change several L298 chips, foresighting they were burned, but nothing changed.
I am sure I am making something wrong, but I don´t know what additional things can I do. I will appreciate very much any help.
Raul
Old 10-25-2004, 04:43 PM
pminmo's Avatar
pminmo is on a distinguished road
Raul,
How you been through these two threads:
Open Source Boards Available, Stepper Drivers and Break Out Boards
Troubleshooting the Simple BreakOutBoard and L297 driver
Phil
[IMG] code is Off
Troubles with L297/L298 ragrillo Open Source Controller Boards 43 10-21-2010 09:10 AM
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 10:04 AM
mounting mill sideways for cleaner screws and chips lesd General Metal Working Machines 1 11-15-2004 09:07 AM
Cook your chips to make more chips :) ToMMY2ooo Bending, Forging,Extrusion... 3 09-07-2004 02:38 PM
Handling CMOS chips owhite General Electronics Discussion 13 04-10-2004 09:29 PM
