Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-18-2008, 10:00 PM
evillamor is on a distinguished road
Parker OEM750 stepper and mach3 follow-up
Need help of my project, i found this tread few months ago and i started to test my compumotor oem650 with mach3, now im having problem trying to have it run, im very confused of the pinning configuration of the oem 650 and the parallel port, or is it serial port of the computer? in the manual of oem 650 says that it has a baudrate of 9600 which i think only need for serial communication, how come that in the tread i read it was configured in parallel communication port?
http://www.cnczone.com/forums/stepper_motors_drives/51845-parker_oem750_stepper_mach3.html#post404813
Old 09-19-2008, 02:23 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
Did you look at the JPG picture for the jumper pin config.
Quote
Now if you have 750x or 650x drives - you can convert them by removing the indexer daughter board and using jumpers.
5 jumpers in the fore ground
http://www.electronicsam.com/images/OEM650.JPG
End quote
I am not completely useless.......I can always serve as a BAD example.
Old 09-19-2008, 02:29 AM
MonoNeuron's Avatar
http://www.compumotor.com/manuals/OEM/OEM350-650.pdf
Page 12 shows you the pin outs and the following pages show what they do.
Old 09-19-2008, 02:31 AM
MonoNeuron's Avatar
Page 18 shows the connections on the parallel port for the step and dir signals. Only a couple of wires are needed on the parallel connector
Hope this helps.
Rich.
Old 09-22-2008, 01:02 AM
Still no luck, I've tried several times of this configuration, also the oem 350/650 controller has no daughter board and already 5 jumpers on it
X axis oem 350/650 (25pin) Parallel port (25)
1 2
2 3
14 18 (ground)
15 18 (ground)
I attached the configuration of the mach3 ports and pins
[IMG] code is Off
Parker OEM750 stepper and mach3 GEORGETOUBALIS Stepper Motors and Drives 10 04-13-2009 05:42 AM
Wanted Stepper Motors, Parker Compumotor A and M Series. Miata2k Want To Buy...Need help! 0 07-14-2008 05:18 PM
Follow the money dynosor Environmental & Alternate Energy 56 11-04-2007 04:33 AM
Follow Up Of My Cnc Put Together Now chris69randy DIY-CNC Router Table Machines 16 04-16-2005 02:40 AM
Please follow the rules CNCadmin BobCad-Cam 0 07-27-2004 09:12 AM
