Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-17-2008, 11:12 PM
blue_steel's Avatar
blue_steel is on a distinguished road
Can I use this Driver with a stepper?
I'm in the process of building my first CNC and would like to start playing around with some steppers.
I have this old driver I used for some Servos but I'd like to know if there's a simple way to have it control a stepper. It's basically a 2-to-4 decoder (74HC139) driving dual H-bridges.
Anybody have some simple ideas for driving the inputs to control a stepper in a bipolar configuration? Would the L297 be able to handle this?
The stepper I have appears to be similar to those in the HP II/IIIs. (5.4v, 1.6A).
Thanks in advance for any suggestions.
Old 09-18-2008, 10:49 AM
Riceburner98 is on a distinguished road
This might help... These chips: http://www.st.com/stonline/books/pdf/docs/1373.pdf are what the "Intelligent Motion Systems" IM483 stepper driver uses (2 of them), they're basically dual H-bridges. They give example circuits in the datasheet, you might be able to use your circuit in a similar manner..
Old 09-18-2008, 11:53 PM
blue_steel's Avatar
Thanks for the info riceburner,
I see that they have circuits which use the L297. Since I've got some samples of those I'll go ahead and give it a try with the h-bridge on my driver board.
Appreciate the help.
[IMG] code is Off
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
Has anybody used this stepper driver? phantomcow2 Stepper Motors and Drives 4 10-26-2005 09:25 PM
New Stepper Driver?? ViperTX Stepper Motors and Drives 3 08-04-2005 06:46 PM
stepper driver flygti General Electronics Discussion 1 04-26-2004 09:48 PM
