Riceburner98,
You're not nuts._) Without getting into the physics of step motors, look at the problem this way: You store a substantial number of joules in the disk and that stored energy must be removed to decelerate the disc to a stop. There is no mechanism in either the motor or the drive to dissipate this energy, so it is returned (motor acts as generator) back to the power supply. A circuit must be built to dissipate this returned energy, usually as an active clamp across the power supply DC voltage.
Unless I slipped a decimal point, my calculations show 230 Joules (Watt-Sec) of stored energy at 3,000 RPM. That is a substantial amount.
Please see the attached .pdf which goes into a little more detail on this subject.
Mariss
LinkBack URL
About LinkBacks
Turns out accelerating (slowly, using mach2) is no problem and it'll sit at 3,000RPM no problems. But on deceleration, the motor turns into a generator and I was seeing 90+V at the power supply! (48v supply) So basically I was dumping 90+V through the IM483 driver chips, and it didn't like it. (rated at 48v, surprised it lasted as long as it did!)
