Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-04-2008, 04:18 PM
nuclearice is on a distinguished road
Vexta PK266-01A - Are these good?
I just found a set of 4 vexta pk266-01a-c23 motors on ebay for $25 and wanted to see if they are worth it. I am building a modified jgro that is slightly smaller than the plans call for and have 1/4-20 threaded rod but want to return that and move up to 1/2-10 acme. Will these motors serve me well? The specs are:
(bipolar series)
166 oz*in
.71 A/phase
40 mH/phase
I will be driving them with the new Gecko G250's @ 48V. If any more info is needed I'll be happy to supply it. Thanks!
Old 09-09-2008, 06:49 AM
Richards is on a distinguished road
The limiting factor with the PK266-01 stepper motors is the inductance. At 40mH, you would need a power supply producing about 200 V (using the formula 32 X SQRT(inductance) = MAX voltage).
If I remember correctly, the G250 likes stepper motors that have inductance around 2.5mH.
Even if wired half-coil, you would need about a 100V power supply to get the most out of those motors. Even the full power G201/G202/G203v stepper drivers are limited to 80V and the G250 is limited to 50V.
I have used a lot of the PK268-02A stepper motors, wired half-coil with both the G202 and the G203v stepper drivers. The inductance for that motor, when wired half-coil, is 3.5mH, which gives a maximum voltage of about 59V. Running that motor at 50V or slightly less, with the G250 might be a good combination.
The PK266-02A motor is rated at 2.5mH, which would make it an ideal match for the G250 (voltage wise); however, keep in mind that it only has about 125 oz*in of holding torque.
Old 09-10-2008, 06:37 PM
Thanks, that was very helpful!
[IMG] code is Off
Need Help!- Newbie, I built my first CNC w/ Vexta PK266-02A. Motor Tuning Pls Help guy2b1 Calibration & Measurement 34 04-11-2010 01:49 AM
vexta PK266 motors - noob questions tranceamerica Stepper Motors and Drives 1 06-28-2007 10:26 AM
5 phase vexta stal Stepper Motors and Drives 2 10-15-2004 07:35 AM
Vexta 266-01b tekno Stepper Motors and Drives 9 08-15-2004 07:48 PM
Vexta Website wakeboard DIY-CNC Router Table Machines 3 02-07-2004 07:03 PM
