| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I am building a gantry style CNC it is all aluminum with a 36''x24'' work surface the type of work will be wood and aluminum sheet metal and the odd aluminum plate 1/4'' milling work i will have coolant for that aplication My question is wat tipe of steper should i spec out Voltage , unipolar ,bipolar vextra ,Amperage degrees, and steps this is confusing because there are so many out ther and i want something strong and easy to configure or replace I a good metal worker but the electronics !!!! Thanks craftech |
| Maybe something like these: http://www.orientalmotor.co.jp/cgi-b...K&frameSize=85 Use Geckos, wired bipolar parallel at around 30V. If this is in your budget, you'll get quite a bit of power for a very reasonable price. You could probably get away with a little less power, but you can never have too much power either.
| If you look at the thread for InventIt 's router, he uses these motors and can get over 300ipm with 1/2-10 5 start acme screws. If I ever finish my first router, I plan on using those motors for my next one. Here's the link to InventIt's thread: My first Router / Plasma Table Buildup...
| Instead of a single thread wrapping around the screw 10 times per inch, there are 5 seperate threads that wrap 2 times per inch. So you still have 10 threads per inch, but you only have to turn the screw 2 times to move one inch. Screw with multiple starts are more efficient than single start screws, sort of midway between single start and ballscrews.
| A Axis and Step and Direction Spindle Setup | mklb | Mach Software (ArtSoft software) | 6 | 11-27-2009 08:19 AM |
| Beta Testers for QMill/CNC discussion | CNCadmin | General CNC (Mill and Lathe) Control Software (NC) | 18 | 11-25-2005 01:33 PM |
| Dirction / Step lines! | bigal | TurboCNC | 2 | 02-06-2005 02:51 PM |
| Step and direction software | bgolash | Gecko Drives | 2 | 12-04-2004 01:29 AM |
| Step and direction source | pauls | Gecko Drives | 1 | 09-03-2004 08:19 AM |
