| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Just a quickie... 8 wire stepper being run parallel configuration - would you run each phase wire up to the driver then combine into the 4 required or splice close to motor and run the resulting 4 back to driver? Cable / wire length will be about 2m overall. |
Not sure I can see why it makes a lot of difference. If you don't have heavy enough wire to hand to effectively handle the current in 2 parallel phases then clearly wire each phase back to the driver, but there's a risk that if a wire drops off/breaks/etc., you could damage the remaining phase as the current limit will be too high for a single coil (assuming a chopper current limiter). Personally I'd wire them together at the motor end as its less wiring effort and neater/tidier. |
| Stepper wiring | monte55 | DIY-CNC Router Table Machines | 4 | 11-23-2006 05:04 PM |
| Quick Question on stepper motors | cspearsall | Open Source CNC Machine Designs | 3 | 06-28-2006 05:51 AM |
| quick stepper electronics question | keebler303 | General Electronics Discussion | 4 | 03-31-2006 07:40 PM |
| Stepper Wiring | JW Peters | Stepper Motors and Drives | 2 | 06-03-2005 07:17 PM |
| Quick servo vs stepper questions | Hack | General Electronics Discussion | 5 | 08-05-2004 01:48 AM |
