Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 10-05-2004, 05:10 PM
CNC Darren is on a distinguished road
need help with stepper motor
hi all i bought 4 of these motors a while back for a foam cutter and want to get back to finishing it once my CNCrouter is done. But I am having a heck of a time figuring out the wiring on them as i'm still a newbie to this. They are 5 wire unipolar. Here is a pic of one, the Applied Motion home page doesnt seem to list them but that doesnt really surprise me as the mfg date is 7-83.
Darren
Name:	CNC log 050 copy.jpg‎
ID:	3554   Click image for larger version
Name:	CNC log 051 copy.jpg‎
Old 10-05-2004, 05:48 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
Find the common centre tap with a multimeter and apply +12V to it. Now take any other wire and ground it, call this #2, now pick another wire and ground it as well, if the motor moves clockwise label it #3, if counter-clockwise label it #1. If it does not move label it #4 (or the motor is knackered). Remove the newly labeled wire from ground, still leave the other two connected (+12 & #2)
Pick another unlabeled wire and repeat the above steps untill all wires are labeled.
The wire numbers are not important, it's the sequence that is.
Hope this helps.
Old 10-05-2004, 06:48 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Mr Bean! What a nice tutorial for labeling the wires. Now, I suppose you picked 12Volts - as thats what the motor was rated at? Is there any "margin of safety" that we can use for "unknown motors"? Eg if it "might" be 5 volts would 12Volts be too much? Seems like when running steppers everyone runs over volts - but watches current closely. Would the same apply to this testing scheme? Cheers and Thanks - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 10-05-2004, 07:15 PM
MrBean's Avatar
Gold Member
Thanks. I didn't think it was worded very well. Hopefully it makes enough sense to be usefull.
Use the motors rated voltage. No need for higher voltages as there's no load on the motor and it not rotating. It's only moving one position in half step mode to determine the "firing order".
If you use a higher than rated voltage and it's not current limited, the motor will make smoke, especially if it's not in continious rotation.
If ratings for the motor are unknown. Start with a low voltage, only hold the wires on for the minimum time it takes to see if there is a CW/CCW move. (test more than one wire in case you picked #2 & #4 on the first go, as you'll see no movement) . If you still see no movement, move to a higher voltage, or the motor is a dud.
I don't know how much overvoltage you could apply to a stationary stepper before it smokes. Not too much I expect, that's why they have ratings.
Old 10-05-2004, 09:07 PM
the common center tap will have the same resistance across all the wires correct?
Old 10-05-2004, 09:50 PM
ok i think i have it. Now i assume that #1,2 would be step and #3,4 would be direction?
Old 10-05-2004, 11:21 PM
Ferenczyg is on a distinguished road
No. The steppers have no wires for step and direction. In purity, all are 'step' except the common. The *rigth sequence* of steps define a direction. The procedure of MrBean only defines a rigth sequence from where you choose your first wire.
Old 10-06-2004, 07:12 PM
hmm ok, I have all my wires numbered here is a pic of my board. SO A=1 a=2 b=3 B=4? and the com would be the center tap?
Name:	CNC log 053 copy.jpg‎
[IMG] code is Off
stepper motor load resistor and figuring out phases? drtuto General Electronics Discussion 7 03-19-2005 03:53 PM
Souce for NEMA 42 stepper motor? Mueller Stepper Motors and Drives 2 03-06-2005 08:59 PM
Stepper Motor Selection dberndt Stepper Motors and Drives 7 12-06-2004 07:50 AM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-02-2004 12:31 AM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 06:58 AM
