Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 08-07-2008, 07:28 AM
dteney is on a distinguished road
Question Strange problem with L6208-based driver
Hello all,
I built a 3-axis driver for my bipolar stepper motors, but it's not working perfectly. I implemented the "typical application" given in the datasheet of the L6208, and also mentionned in an app note from the manufacturer.
See p19 of the datasheet: http://www.st.com/stonline/products/...re/ds/7514.pdf
The problem
- If I power up the board, then I start "jogging" in Mach3, the motor vibrates or move randomly in no precise direction.
- If I start sending pulses with the power OFF, then I turn on the power of the board, then the motor rotates smoothly in the commanded direction. But if I stop and restart again, the motor again vibrates or rotates randomly.
I tried to add more capacitors to improve filtering of the power supply but it didn't help. I'm running in full-step mode, but I wonder if switching to half-step would change anything.
I really don't know how to could solve this problem, so I'd be really glad to get some help.
Thanks in advance.
Old 08-08-2008, 07:22 AM
moonrock is on a distinguished road
Much like to failure of one of phases(a or b) during power up. If current in one winding is present, but in another is absent - motor is start to twitch and then can run to random direction.
Can you show oscillograms from SENSEA and SENSEB pins?
Old 08-08-2008, 07:32 AM
I can't, I don't have an oscilloscope.
What could be the cause of that ? What is really intriguing is that it works every each time if the card already gets pulses when it is turned on.
Old 08-08-2008, 08:34 AM
Bulding PWM based designs without osc is really hard
Mmm. May be check again circuits around RESET, EN, VREF pins?
Or replace IC at all?
Old 08-10-2008, 08:04 AM
I checked the circuit around those pins, and I already changed the circuit, it didn't help. I already tried another motor, too.
Right now I'm using a stabilized 12V power supply. I measured the voltage, which is normally almost 12V, but it increases to a bit more than 13V when I try to make the motor rotate. Is it normal ? Could it be the cause of my problem ? I measured the voltage on the logic inputs (reset, enable, etc.) it always is +5V or 0V.
Thanks again for your help.
Old 08-10-2008, 01:13 PM
It works. I switched to half-step mode. I don't have an explanation but it works now.
[IMG] code is Off
Strange problem ! BP II interact 4 bherr Bridgeport and Hardinge Mills 11 08-28-2008 09:48 AM
Strange problem with HT 40 hell_pk Fanuc 1 04-29-2008 05:23 AM
CNC strange problem huben_123 TurboCNC 4 03-14-2008 06:12 PM
Strange G03 problem sploo Mach Mill 4 11-14-2006 05:24 PM
strange motor problem sp00k1e General Electronics Discussion 4 03-23-2004 05:46 PM
