| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I have stepper motor with Nominal voltage = 4V Resistance/phase = 4.2 Ohm Amps/Phase 0.95A I saw the torque graphs for the motor using 24/48V as supplyvoltage and I got lost... Is my math correct: If I use 4V I will need 0.95A power supply and If I put 24V on the motor I will need i=U/R i=24 V / 4,2 Ohm i=5,71A And so I need Stepper controller that supports 5.71 A ? Am I doing it right? |
| Amps are always the same regardless of the voltage, .95a/phase. How many amps you need for your supply depends on the drives. Some drive require the full rated current for each phase, and some need as little as 1/3 of the rated current for a single phase.
| Problem- Wiring confusion | wendtmk | Automation Technology Products | 11 | 05-19-2008 08:08 AM |
| G52 confusion | davek | G-Code Programing | 2 | 09-08-2007 08:01 AM |
| confusion | serry | DIY-CNC Router Table Machines | 4 | 04-27-2007 06:40 PM |
| Manual.doc vs. .ini confusion | medved | TurboCNC | 2 | 04-04-2006 10:18 AM |
| 8 wire stepper confusion | audioandy1762 | Stepper Motors and Drives | 5 | 03-28-2006 03:58 PM |
