Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-28-2008, 09:28 AM
amishx64's Avatar
amishx64 is on a distinguished road
Stepper innards detached?
Hey guys. I'm new to the zone. Looks like a great place.
I recently have decided to build my own CNC for various purposes, including PCB milling. Having built 70% of my machine thus far, I have started setting up my controller board with mach 3 and my stepper motors.
I have a few questions about how my stepper is behaving.
In mach 3, when ever I set the velocity above 3, the stepper starts spinning for half a second, then the motor's axis stops, but still sounds like the coils are still spinning internally. After a few seconds the pitch becomes very high.
Does anyone else have this problem or is this normal?
Also when my stepper is on but not doing anything, I can still hear a slight buzzing internally.
My last question: What are the Step and Dir pulse values in Mach 3 for? Why would I want anything but 1 and zero? any advantages to changing this? It dosn't seem to make a difference.
400oz/in steppers
12v (I know *sigh*)
8 wire in bipolar series
Edit: I'm going to try the other two I have. The motor seems easy to stop when using pliers.
Old 07-28-2008, 10:10 AM
amishx64's Avatar
Update: other motors behave same way. After left on for a while, motors get pretty warm.
Old 07-29-2008, 10:16 PM
H500 is on a distinguished road
With 12v, you won't get much speed out of the motors. The sound you hear is when the rotor loses sync with the rotating magnetic field.
Try lowering your acceleration.
Old 07-31-2008, 08:06 AM
amishx64's Avatar
Oh. I know I should be using a higher voltage but I didn't know that was the reason.
Awesome. Thank You.
Old 08-02-2008, 09:21 AM
johnmac's Avatar
johnmac is on a distinguished road
Sounds like the motors are stalling. Using 12V motors will add a challenge. You didn't say what voltage you are running the steppers at. Done correctly, you can run them at a higher voltage and get better top speed. The controller you are using will determine the maximum voltage and how the current will be limited.
John
Old 08-02-2008, 07:25 PM
amishx64's Avatar
Sorry. I meant to say that I am running the steppers at 12v while they are rated at 4.2v, 3A. My controller can accept a higher voltage, but I am using an ATX PSU from a PC.
Thanks for posting.
Tags
mach 3, problem, slipping, stepper
[IMG] code is Off
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
Detached Garage Shop - CNC Choice hflwaterski DIY-CNC Router Table Machines 7 11-30-2006 12:32 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 07:35 AM
