Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-25-2008, 06:53 PM
Santa Fe Al's Avatar
Santa Fe Al is on a distinguished road
Stepper Motor with 2 Drivers ??!!?
Hi All,
For some time I have been searching the Zone (Active and Archived) in an attempt to ascertain whether the outputs from two drivers can be attached to the stepper motor leads, perhaps using appropriately sized diodes for driver output isolation. So far, I have only found references to using two stepper motors with one driver - not a good idea, but possible. This is not what is wanted.
The driver I am looking at is on e-Bay: ebay.com/Stepper Motor Controller & Driver (2 Control Modes) Item number: 140251064845 - or similar - and perhaps a G540 or 3 G251's.
I would need to be able to power down whichever driver I will not be using for a given stepper motor. Is this correct?
Since they are both complete drivers, I can't put the output of one into the input of the other. Hence the paralleling of drivers.
The question remains, what will the affects be if they are both still connected to the stepper wires with one driver powered down? I'm trying to keep things as simple, with the use of the least number of switches, as possible.
If the affects aren't good, I would be required to:
1. Power down the driver in use.
2. Use a 4-Pole switch to re-route the stepper motor wires
to the second driver
3. Power up the second driver
4. Go back to step 1 to return to the original driver.
The eBay driver would not be connected to the BOB.
At this time, I do not know if I would need to power down the computer, get out of Mach 3, trip the E-stop in Mach 3 or what?
If no-one can help, I suppose a pendant would do what I want. I just don't know enough about them, yet, to envision its use without a lot of research and study.
I am hoping to have just a couple of buttons in my hand by using the above method. Also, I think it would be a lot cheaper. - The driving force!!!
Any information or ideas, pro and con, will be greatly appreciated.
Al
Old 07-25-2008, 07:03 PM
jhowelb is an unknown quantity at this point
This driver will operate ONE motor in one of TWO MODES!
IMVHO......stick to a proven technology. Like, maybe Gecko?
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 07-25-2008, 09:26 PM
I had intended to use the eBay drive only in the "manually move one stepper at a time function". Otherwise, Geckos all the way.
Al
Old 07-25-2008, 11:00 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile Why not add a MPG or Jog Dial instead?
Al,
http://littlemachineshop.com/instruc...structions.pdf
Jeff...
Old 07-26-2008, 05:54 AM
ger21's Avatar
Or even just the standard jog keys on the keyboard? Al, your making it way too complicated, and asking for trouble imo.
Old 07-26-2008, 08:40 AM
Thanks guys,
I figured it wasn't the right way to go, but I just had to make sure. Sometimes my imagination gets the best of me.
It looks like I'll be heading in a different direction.
Thanks,
Al
[IMG] code is Off
Cobra Stepper motor drivers Jason Marsha Viper Servo drives 11 09-10-2007 06:26 PM
drivers for stepper motor? visky Stepper Motors and Drives 0 01-22-2007 02:27 PM
stepper motor drivers nurseling General Electronics Discussion 5 01-16-2007 04:43 PM
Stepper motor drivers ? Clyde Crashkop Stepper Motors and Drives 7 11-26-2006 05:39 PM
stepper drivers DDM DIY-CNC Router Table Machines 1 01-19-2004 12:58 AM
