Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-15-2008, 08:38 PM
offthewall is on a distinguished road
Random Pulses to Motors when Idle
I知 getting random pulses to my steppers when my machine sets idle, and sometimes when I知 running a part. Seems to be in the X axis, and every now and then in the Y axis. I知 running a Taig machine with their step & direction add on board with Mach 3. Could it be a setting in Mach 3, or shoould I be looking somewhere else. It moves the axis slightly when it gets the surge.
Thanks for looking.
Steve
Old 07-15-2008, 09:42 PM
ger21's Avatar
Run the mach3 driver test (drivertest.exe) and see if you get a flat line. It could be a windows service causing glitches n Mach3.
Old 07-16-2008, 07:02 AM
Zappautomation is on a distinguished road
May also be electrical noise, are you using shielded cables for the signals?
Thanks for looking.
Steve
Zapp Automation Ltd
www.slidesandballscrews.com
Old 07-16-2008, 07:38 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question Easy test.
While it is sitting idle and pulsing occasionally, unplug the parallel cable.
If it stops, blame signal levels.
Bet if you exit Mach3 with the cable in you will soon rule out Mach3 causing the problem.
Mach3 is ROCK SOLID.
You have some form of earthing problem.
Try a different cable. Some cables are poorly made and skimp on earth circuits.
3.3v signal levels from later PC also erode the noise margin.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 07-16-2008, 07:45 PM
Thanks for all of the suggestions. I did run the drivertest.exe, and although I didn稚 get a dead flat line the variance was from low of 38 and a high of 45. When you say shielded cables, do you mean the parallel cable, or the motor cables? I will try all of the great suggestions.
Thanks Again!!
Old 07-16-2008, 09:07 PM
neilw20's Avatar
Smile PC Cables.
PC cable should be shielded to stop interference corrupting your control signals.
No gain will be had by shielding your motor cables for your problem.
Old 07-16-2008, 09:26 PM
Thanks Neil. I値l switch that out with a shielded cable.
Steve
Old 07-16-2008, 10:07 PM
neilw20's Avatar
Exclamation Random Pulsess
If you are getting random pulses when stationary, you can straight away split the problem by un plugging the cable.
If you get no random pulses with the cable unplugged, then they are probably not being introduced by the machine.
Plug the cable back in and unplug it from the PC.
Still good? If no, blame the Machine/Cable combination.
Yes, start to blame the PC.
Conquer and destroy.
Each result is not always 100%. Don't just think 'THERE IT IS!'
Because results can be less than 100% then the decisions must be too.
Don't just jump to conclusion you need a new cable.
It is more likely an earthing problem, and have to eliminate one section at a time.
Trying things just leads (no pun intended) to error. Analyze the problem and you WILL fix it.
[IMG] code is Off
Motor screams and gets hot while idle methuso Hobbycnc (Products) 1 05-14-2008 12:52 AM
G201, no holding power at idle Zumba Gecko Drives 3 02-21-2008 12:26 PM
automatic idle-current reduction & belt drive ?? Georg DIY-CNC Router Table Machines 1 11-06-2007 03:11 PM
Whine / squeal noises when machine idle bkraz Bridgeport and Hardinge Mills 5 02-09-2006 05:29 AM
Step Pulses per second? thielert TurboCNC 2 11-06-2003 12:35 PM
