| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| Hi Ok I wired up my stepper motors (Mema23) and plugged them in to test my system and the motors, as soon as the system comes on the stepper motors start acting funny 1 makes buzzing sounds and gets hotter and hotter to the stage you cant touch it 1 gets hot but not as hot as the other but doesn’t make any sounds 1 does nothing not hot or noisy Now I never got to the stage of testing them as I shut my system down before I damaged anything, I did test them on different axis connections to see if it was my controller board (HobbyCNC EZ driver) and they did the same. Is it the way I wired the stepper motors? The controller board? Or the stepper motors? Can any one point me in the right direction please, thanks for your time also. |
| Hi thanks for your reply I wired them like this > http://img.photobucket.com/albums/v4...2306/wires.gif > > The others in the image that dont show any resistence I just left > blank > > By the looks of it to me its > > Black as a commom > white + red is A > Red is a > > White is a common > Green is B I was told thats ok but if the motors go the wrong way when running to change over A - a or B - b but not both. Motors are these http://www.techkits.com/#slosyn for power, I am running at 36v as again I was told that this would be best for my motors and board, hope it is. thanks |
| for the amps I forgot to alter that, the board is adjustable could this be the problem then? also erm do you think I could have broken the motors? also sorry any tips on how I test that I have set each axis to 1 amp with my multimeter? |
| Yes! Running 3Amps into a 1 amp motor will definitely overheat them. You won't know if they are cooked until you try them at 1 amp though. Amps are measured in series. If your multimeter has a DC Amp setting for 3 or more amps, (or a plug for a test lead) then set it up that way and then clip the meter leads in between the drive and one of the motor leads. Make sure the connections are TIGHT. If a wire comes loose, it will cook your drive. CR. |
| thanks for all the replies I feel really daft after my last post I got the paper work out for my HobbyCNC EZ board and found info on setting it all up for the amps I am going to set that all up and see again after I just hope I havent done anything to the motors, I have a feeling one is faulty anyway as I tested every one of them to check the cables and one was showing a very different rating on one cable and that was the one that stayed cold also. I will be back with one good answer or a bad one. again thank you every one. |
#11
Hi the two other steppers go warm like some one up there said they will but one stays cold, I checked them now that I have sorted the amps out and the other two are hard to move by hand when powered but this one that is cold moves freely so I guess its broke like I thought ![]() When I said checked the wires I meant to find out how to connect them to the driver board I checked the resistance of all the wires on one stepper and got my answer like this diagram I did: http://img.photobucket.com/albums/v4...2306/wires.gif (yes the long way round but I learnt something from it) after I did one just to fully check I did the other two and one stepper was showing a different resistance rating on two of the wires from a com to I think it was wire a instead of a 4.2 it was a 2.3 from what I can remember. I am now just setting things up to test the motors to see if I can get them to move and work will be back |
#12
| Black to Red or Black to Red/White should be 4.9 Ohms. Red to Red/White should be 9.4 Ohms. White to Green or White to White/Green should be 4.9 Ohms. Green to White/Green should be 9.4 Ohms. Try reversing direction on the "cold" motor. Try the "cold" one on a different axis driver. CR. |
| L298/L297 strange stepper motor noises | cnc kiwi | Stepper Motors and Drives | 7 | 12-26-2007 10:18 AM |
| Stepper acting funny. | Smackre | General Electronics Discussion | 1 | 07-13-2006 08:59 PM |
| Stepper motor acting weird. Help! | astro | Stepper Motors and Drives | 7 | 05-28-2006 10:18 AM |
| Help Needed! Stepper motor acting up... | nuplowboy | Stepper Motors and Drives | 1 | 10-02-2005 01:03 PM |
| strange stepper heating | Stevie | General Electronics Discussion | 5 | 05-21-2004 10:03 PM |
