Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-29-2008, 10:47 AM
jeffg is on a distinguished road
Will belts be good for this design?
Hello all I am building my third router table 5x9. I am going to use bishop wisecarver dual vee low pro linear bearings on the x and y (got a good deal on ebay) My gantry finished will weigh 145lbs. for the drive on x and y i have bosch t-5 belts and pullies, the pullies are 24 tooth so if i use a direct drive the x and y will move 120mm or 4.74" per rev. The x will be dual drive with 500oz steppers and y will be single drive with 500oz steppers. My queston is are the 2 500oz steppers going to be able to move my x at a reasonable speed? Any idea on what the preformance of x and y might be? I know this also has to do with the power supply and stepper drives but lets assume that the steppers are working at peak preformance. Thanks for your help jeff
Old 06-29-2008, 05:53 PM
ger21's Avatar
They'll probably go very fast, but you may need a low accel. Your resolution won't be very good, either. You might want to gear it down a bit to get more resolution and quicker acceleration.
[IMG] code is Off
L Belts BigBee Want To Buy...Need help! 0 03-18-2008 11:43 AM
Could anyone recommend a good book on learning mechanical design? nagjames Mechanical Calculations/Engineering Design 21 01-21-2008 11:21 PM
Finding Engineering Design Software For Automatic Machine Design hellokitty General CAM Discussion 0 01-06-2008 12:39 AM
Where is a good place to get pulleys and belts for servos Ed Williams Servo Motors and Drives 3 04-17-2006 08:42 AM
Good price on Design pro upgrade? kmcwhq Alibre Design 1 01-13-2006 12:08 PM
