Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-28-2008, 06:58 PM
max90272 is on a distinguished road
DO I need LIMIT SWITCHES or E-stop??
HI guys,
I am currently building a homemade CNC mill from scratch and am learning quiet a bit on all aspects. I have retrofitted 3 axis from unused equipment with step motors controlled by a micro driver. I am using KCAM, and just last night downloaded MACH3.
I was curious as to if I need limit switches or not. I noticed that in KCAM you can tell the computer how long each axis is, which I figured would be the equivalent of having limit switches. Do I still need limit switches or E-stops, and why?
THANK YOU
MAX
Old 06-28-2008, 07:26 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Max. Welcome to the Zone!
With Steppers, You can probably live without limit switches, because a stepper will just stall, and not burn up like a servo will. And "soft limits" like you describe are also available in Mach3. However, you MIGHT want some Home switches.
E stop is a completely different thing. You NEED Estop, because the one switch disables all mill movement in an emergency. You also could benefit from a Charge Pump--which disables the steppers if windows goes a little crazy.
CR.
Old 06-29-2008, 05:59 AM
jphagen is on a distinguished road
drive bumper cars ?
Drive a real one without breaks?
Even with steppers stalling depends on the momentum, will wreck the
machine.
Just a thought.
Old 06-30-2008, 05:57 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
E-Stop is essential. There's different opinions where to put it- on one of my lathes it's high up which I think is wrong. On my other lathe it's near the floor... which is where you will be if things go "bang"- you automaticaly duck.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 07-07-2008, 08:50 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Consider this. If you have an error in your NC and you run it for real you could potentially damage an expensive tool and loose the workpiece. So investing in a 3 switches really pays for it but it wont make your NC flawless
Besides how hard is to hookup 3 normaly closed switches to XYZ limit pin.
Konstantin.
Old 07-14-2008, 11:45 AM
eightball is on a distinguished road
Most controller boards have limit and e-stop connections so might as well use them. Ive seen e-stops for around $10 for the traditional type of red button swich, and limit switches for $2 from enco (get the light duty ones, no need for the 10A limits unless you have some really weird cnc controllers)
[IMG] code is Off
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
Limit, Home and E Stop Switches Mr.Chips General Electronics Discussion 15 01-17-2007 09:02 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
