| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Until now all of my problems have had to do with trying to make some kind of a change or trying to understand something. This post has to do with suddenly being out of business. And while I'm mostly a hobbyist I'm also in the middle of developing a product which will be marketed to hospitals to be used in emergency situations. So I hope I can resolve this quickly. My X axis has gone crazy. Right smack in the middle of making a part it started making a grinding sound switching directions back and forth ignoring the g-code and spoiling the piece. A few times when this happened I clicked on STOP and then maneuvered the axis with the keyboard. When moving the axis that way I continue to get the grinding OR I get a faint sound from the motor that produces no movement. I ruled out a faulty g-code by writing a simple program that would have it going from X north to X south 20 times. During that program it repeated the aforementioned behavior. So it seems to me that I must have a bad Gecko or a bad motor. Does anyone know how I can definitively determine if it's the motor without swapping it with another axis. My Y motor won't work because it has two shafts while my X only has one. The Z axis might take hours to show up as defective because it doesn't move much. The absence of failure on the X axis with the Z motor would leave me wondering if it just hadn't failed "yet". Would appreciate any advice on how to know for sure if it's the motor. PS: Motors are 640oz |
| Motors rarely go bad. Only time I have seen motors go bad was when they got too hot. To hot is when you can smell the varnish melting on the wires inside the motor. To hot is when water sizzles on the motor casing. 99.9 percent of the time the Gecko module has gone bad. Unplugged, power off. Motor disconnected from Gecko Module. Measure the resistance between the Phase A and B, and Phase C and D. If they are different, the Gecko is definitely bad. If either is low resistance, less than 50 ohms, the Gecko is definitely bad. The symptom you describe occurs when one of the motor phase drivers has gone bad in the Gecko Module. Usually you smell the bad module, but not always. Dennis www.super-tech.com |
| Is this a stepper motor? or closed loop servos? my guess is steppers, and your accel and decel AND/OR rapid traverse is set to fast! if the stepper motors are set to accel to fast, they will just twitch a little and not go anywhere. and do what you are describing. This could happen even if everything was perfect for the last year, then someone didnt notice the ways didn't have oil on them and they are dry, changing the conditions. If not the case, try to add more information, to this post, about your cnc. |
| So MR IQChallenged, You bail out of this thread: http://www.cnczone.com/forums/showth...t=59994&page=4 amd start a new one leaving me hanging on your keyboard jog problem. I'm done with you. How rude. |
Both pairs of wires to motor show zero ohms. I probably need to change hobbies. |
| IQ, Are these drives stepper or servo? I need to know so I can tell you how to do a MOSFET diagnostic. The MOSFETs don't just fail, so something had to trigger it, most likely a short of some sort on the power supply cables. Marcus Freimanis |
Please don't leave. Just now logged on. Gonna put together a post. |
#10
| Just now finished switching my motors (X and Z). Figured I let the Z do some fast up and down to see if it would do bad with the X motor. It did fine. Conclusion: Nothing wrong with X motor. Then I put the X axis through its paces with the Z motor. Problem recurred. Grinding and attempting to change course. Conclusion: Something other than the motor. Important to note that this system has been stone reliable for a year or longer with lots of use. This is new and sudden. |
#12
| IQ, Take your multimeter and set it to Ohms. A digital meter works best here. Now, take the ground lead on the multimeter and connect it to terminal 1 (power GND) and connect the positive lead to terminal 3. Make sure it does not read below 100KOhms, and move the positive to terminal 4. Do the same thing and move it to terminal 5 and then 6. Now move your ground lead to terminal 2 (PS +), and do the same test from terminals 3 to 6. If any of them read below 100KOhms, and if they do it will generally read about 10 ohms or open, then the MOSFET is blown. You can send the drive back to us if you are uncertain and we can test it here slightly more rigorously and repair it if possible. You can feel free to give me a call if you want to go over more options at (714) 832-8874. Marcus Freimanis |
| Looking For A Job- New Business | Stran | Employment Opportunity | 3 | 05-02-2008 09:03 PM |
| Business Wanted | kvsprecision | Product Announcements & Manufacturer News | 0 | 04-10-2008 10:32 AM |
| how to start your own business | Bozzz74 | Mechanical Calculations/Engineering Design | 2 | 08-22-2006 03:53 AM |
| New business name | trubleshtr | Polls | 24 | 08-16-2006 06:48 PM |
| My own business | spottiepop | CNCzone Club House | 6 | 05-30-2006 11:56 PM |
