Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-22-2008, 03:05 PM
dak70 is on a distinguished road
Stepper Motor Short circuit??
I have a cnc machine with this motor..(STP-MTR-23079) from automation direct. Its a NEMA23, Bipolar.
The gecko drive died. I replaced the gecko drive controller and now the fuse from the power supply to the gecko for this motor blows only with the motor connected. If I disconnect the motor and power up the system the fuse does not blow. If I connect an older motor that was replaced previously the fuse (5amp ceramic) still does not blow.
Is there a way to check this newer motor for an internal short with a multi-meter? I wonder if something to it when the gecko blew; or is this motor what killed the old gecko drive.....
Thanks in advance!
Dennis
Old 06-22-2008, 09:07 PM
neilw20's Avatar
neilw20 is on a distinguished road
Exclamation Ohms rules.
Each winding should have a similar resistance. Spec sheets should give value.
There should be no measurable continuity between the two windings or to the frame of the motor.
If you you don't have 2 isolated windings of similar resistance find another motor.
Notice how using the correct size fuse protected the electronics.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
[IMG] code is Off
Short circuit question Tomax General Electronics Discussion 12 04-29-2008 09:46 PM
Need Help!- DIY stepper motor control 4A circuit?? veenie Stepper Motors and Drives 1 03-19-2008 08:04 AM
stepper motor circuit syawal Stepper Motors and Drives 2 12-19-2006 07:59 AM
RQ: Bipolar stepper motor driver circuit elektronchika Stepper Motors and Drives 2 12-21-2005 05:29 PM
