Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-13-2008, 11:45 AM
12step is on a distinguished road
need data sheet/specs for a SANYO DENKI Step-Syn 103-714-0343
Hello,
this is my first post, my name is Bernhard and I'm writing from Munich, Bavaria.
I found a nice stepper motor in a surplus shop, hoping to use it in a project where a lot of torque
will be required
The motor has 6 wires:
white with blue stripe
purple or magenta(?)
blue
white with red stripe
black
white
and the label says:
Step-Syn
STEPPING MOTOR
TYPE 103-714-0343
SHARP PN RM0TS0006CEZZ
DC 4.95V 1.8A 1.8 DEG/STEP
LOT NO. 11526
SANYO DENKI CO.,LTD.
6037608-2 MADE IN JAPAN
Could somebody please point me to a datasheet or give me some essential specs?
Thank you very much & bye...
Old 08-24-2008, 06:40 PM
h_nik007 is on a distinguished road
Smile hi my friend
i think u can find ur need in this 2link:
http://www.active-robots.com/product...r-motors.shtml
http://www.saelig.com/miva/merchant....tegory_Code=MC
Old 08-26-2008, 12:08 PM
irving2008 is on a distinguished road
Originally Posted by 12step View Post
Hello,
will be required
blue
black
white
and the label says:
Step-Syn
STEPPING MOTOR
TYPE 103-714-0343
LOT NO. 11526
You are very unlikely to find a datasheet for that exact motor. The three digits 714 show that its probably a 56mm (NEMA23) frame but the xx4 means its probably a special manufacture (catalog parts have 2 digits), probably for a printer or scanner, and the 6037608 part # suggests its out of an IBM product as that looks like an IBM part # (probably from an IBM badged, Sharp manufactured product).
The best you can do is look at the similar parts in the Sanyo catalog - this is likely to be a fractional Nm motor, maybe .6Nm, but the best way to find out is to measure the holding torque.
If you're looking for a lot of torque you need a bigger frame motor - NEMA34 or bigger... you might be lucky and find that in a surplus store, but usually what comes out of printers etc are low-torque motors...
[IMG] code is Off
Step-Syn Stepping Motors Sanyo Denki Shanghyd Stepper Motors and Drives 1 01-16-2011 11:47 AM
Sanyo Denki BL Super Mod. 65BM.. data Paraprop Servo Motors and Drives 6 07-05-2009 04:02 AM
Help finding information on Sanyo Denki "Step Syn" IBM stepper motor Oracle_9 Stepper Motors and Drives 12 06-08-2007 12:55 PM
Sanyo- Denki Step Syn motors need some help on driver for rollin_ballz1 DIY-CNC Router Table Machines 0 03-07-2006 08:21 AM
Step-Syn from Sanyo Denki tecno General Electronics Discussion 4 11-09-2003 06:06 PM
