Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-11-2008, 07:00 AM
radcnc's Avatar
radcnc is on a distinguished road
Wiring this stepper motor
Superior electric Slo-Syn Motor M062-LE-511E
Can anyone help with wiring, this to my controller
Old 06-11-2008, 07:43 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
What make is your controller? How many wires to the motor? (not counting encoder wires) Do you intend to use the encoder?
CR.
Old 06-11-2008, 09:10 AM
radcnc's Avatar
My stepper Motor
Motor has 8 wires, and I have the Xylotex 4 axis controller, and I would like to use the encoder but I don't know how to hook it up.
Old 06-11-2008, 10:14 AM
You can't use the encoder with a Zylotex board. An eight wire stepper can be wired unipolar, Bipolar series or Bipolar parallel.
Parallel is best. There are 4 coils in this motor. (2 wires per coil.) Use an ohmeter to find and mark the wire pairs that connect to a coil. Wires to a coil may be color coded:
EG: red/red white stripe.
Once you have the coils identified, wire them Bipolar Parallel as here:
http://www.xylotex.com/Windings.pdf
CR.
Old 06-11-2008, 10:53 AM
radcnc's Avatar
Thank you for the help
What about using the encoders, what controller would I get to be able to make a closed lupe system? Thank you again, do you know what torque these are.
[IMG] code is Off
Stepper motor wiring Martincho Stepper Motors and Drives 9 10-10-2007 10:00 AM
Stepper motor wiring smitty Stepper Motors and Drives 11 03-05-2005 04:58 PM
Stepper Motor Wiring Sanghera Stepper Motors and Drives 5 11-06-2004 04:33 PM
