| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello all ! Last time i was running my controller - it was working well. I'm using allegro driver's 5804 TYPE. used the circuit idea and design from here: http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/3axis/ It controls 3 axis. about 2 days ago I have been trying to run a new type of motor: MAE HY 2220 0210 AX08 I have the wiring diagram and I have checked and double checked the wiring of the motor. Yet, on start up- it locks and seems ok but - When i try to get it to make "steps" - it's get back and forth for every step. checked the software - Kcam. - is ok. Not only that I got this problem, when I got back to the older motor - which has previously worked fine - I get the exact same problem. some facts you should know : 1.I got to mess up with the wiring of the parallel port.as the screws fastening it were lossed. 2.I got a bigger AMPRAGE power supply for the new motor to run. same voltage. about 3 times more available amprage say from 1 to 3 amp's. 3.The Allegro driver's are coupled with a "HEALTHY" heat sink with a fan so overheating is not in mind... 4.think it could be the 5v supply to the logic part of the controllers ?! 5.Supply is 24 v with up to 3 Amp's. voltage for logic part supplied of 7805 stabalizer as appears on the circuit diagram. 6.Tried it on a diffrent computer - same problem. Any help would be appreciated... Thanks from advance Nir Bar |
| Cycletrol DC Controller Problems | pzzamakr1980 | Mini Lathe | 21 | 01-23-2011 08:54 AM |
| Problems with steppermotor, controller and driver | eagle550 | General Electronics Discussion | 0 | 12-31-2007 10:27 AM |
| Controller problems | dfurlano | Xylotex | 4 | 11-11-2007 08:34 PM |
| Motor/Controller PROBLEMS | wdenny | Stepper Motors and Drives | 10 | 05-04-2007 06:58 PM |
