| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| usually they don't give much trouble, especially if the set screw locks down onto a flat on the shafts...I _assume_ we're talking about the style that uses set screws through the coupler onto the shaft flats.. a wee little dab of silicone onto the setscrew will help a bit.. never had any problems with the 'clamping' style that have a machined slot and use screws to 'squeeze' onto the shaft... more money though... ..enjoy.. Last edited by vladdy; 06-01-2008 at 02:47 AM. |
| I currently use the cheapies from princess auto...5/8 spider style complete set for 3.49.....need a reasonably rigid motor mount, with the split style or machined multiple slot 'bellows' type the is some additional alignment support comared to the lovejoy or spider types.. ..enjoy.. |
| Another thing I was thinking of was to buy some cheap couplers and bore out the set screw and tap for a larger set screw.What about counter sinking the motor shaft a little just to recieve the set screw,would it be worth it even,just a thought?Also thanks for the responce,cheers. |
| didn't even think of the type of shafts you must have... I assumed your shafts had a flat machined onto them...it's been a while since I've looked at mine, and all have a flat on them...setscrew does'nt come loose with that style... oops... even if you use a dremel or die grinder to put a bit of a flat where the setscrew bites, it will help quite a bit.. ..enjoy.. |
| Helical couplers for $5 !!!!!! | ger21 | DIY-CNC Router Table Machines | 10 | 03-27-2007 03:58 PM |
| Do the jaw couplers on MSC have backlash? | radicooldude | Benchtop Machines | 6 | 03-17-2006 02:37 PM |
| shaft couplers | dgalaxy | Benchtop Machines | 4 | 02-01-2006 11:18 AM |
| Good Shaft couplers | klick0 | General Metalwork Discussion | 5 | 01-01-2006 08:23 AM |
| shaft couplers do i need | craftech | DIY-CNC Router Table Machines | 3 | 11-29-2004 09:26 AM |
