| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| could somone please tell me what kind and where to get resistors for these stepper motors (the 305oz model) http://www.hobbycnc.com/products/stepper-motors/ i will be using two of them each with it's own resistorand one more thing why does stepcalc say that for a 3amp step motor i need a 6amp power suply thank!!! |
Shawn, Do you have a Hobby CNC Driver Board? If so you do not need resistors for the stepper motors. There are adjustable potentiometers on the Hobby CNC board that you set for the current rating of your stepper. Are you using two or more stepper motors, if you are that is the reason for a 6 amp supply. It is possible for all motors to be active at the same time, when additional motors are active the current demands are greater. A six amp supply for a pair of three amp steppers is a little overkill however it cant hurt. Jeff Alessi |
| here is the drive that i use http://dtllc.com/4xcnc10b.html what i want to know is if i run the steppers at 32volts and there rated 4.2volts 3amps then what size resistor do i need and where can i get it (sorry to be such a pain) |
#11
9.2 Ohms 18.133 Watts round up to 20 Watts Shawn, You can call Delagrange 260) 456-4208 He is probably home, double check my calculations. You may need non inductive resistors! Jeff... Last edited by jalessi; 05-28-2008 at 09:29 PM. |
| resistor question | plast744 | General Electronics Discussion | 8 | 07-10-2005 02:20 PM |
| Steppers and resistor-question. | viktorcnc | Stepper Motors and Drives | 10 | 04-05-2005 03:38 PM |
| amp set resistor | Don C | Gecko Drives | 6 | 02-10-2005 02:41 PM |
| Resistor for gecko | bgolash | Gecko Drives | 1 | 12-13-2004 01:07 AM |
| Current Set Resistor | CRFultz | Gecko Drives | 0 | 08-06-2004 12:48 PM |
