Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-04-2004, 05:01 AM
Loffy is on a distinguished road
12v 1amp
I bought a 4XCNC10A from Delgrange and since I'm a electronics n00b I need some help...
My motors are Vexta
PH268-22: 0,882Nm (unipolar), 0,68A (unipolar) -> 0,48A bipolar
PH299-03: 2,16Nm (unipolar), 1,0A (unipolar) -> 0,71A bipolar
I was told that I need to put 12ohm resistance and 18ohm for the two types of motors if I want to run them at 24v. The resistance goes to four of the six motor leads. Do I put in these to protect the motor electronics from the higher voltage..? The electronics shop that I went too didn't have exact 12 and 18 ohms that I wanted so I wonder if its possible to use higher or lower resistance. How can I calculate this give the motor data above and 24v?
Another thing was that when I talked to the guy in the electronics shop he said that I need more than the rated amp of the motors when the motor starts so he suggested that I should buy a 10 amp power supply.. Is this so or is the actual need of the motor only 1a if it say so on the motor?
If I have 3 12v 1amp motors, then I need 12v 3x motor amp for it to supply the 3 motor?
One last question for now.. What happens if I supply more amp than recommended and need is this harmful to a motor?
Thanks for any feedback.
Old 09-04-2004, 06:30 AM
sendkeys is on a distinguished road
Old 09-04-2004, 07:36 AM
Thanks for the explanation
Originally Posted by sendkeys
also...
you're looking at alot of money here in resistors. (unless you find them in a surplus store) you might find it would be cheaper and easyer to buy say a hobbycnc chopper or a xylotex controllers. They are both microstepping. so that will help alot.
Ok are you saying that if I have a xylotex controller I don´t need to have any added resistors and I can hook the motors directly to the controller..?
Old 09-04-2004, 12:56 PM
yep you have to set the "max amps" with a adjustment on the board but that is all
[IMG] code is Off
running stepper at 12v mikejkd Stepper Motors and Drives 2 05-24-2005 02:42 PM
12V vs 24 mwestern DIY-CNC Router Table Machines 3 06-01-2003 12:32 AM
