| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
greetings ! I made exact copy of this driver board http://pminmo.com/3axis/3axis.htm only changes I made are instead of IRLZ 44 mosfet I used IRFZ 44 I am using some small unipolar steppers-3.9 V,1.3 A ,12 V power supply and current limiters 5.6 ohm ,9W resistors. Now everything works fine,but resistors seem to heat pretty much,I can not touch them! mosfets are not heating at all,even without heat sinks Is this normal for current limiters to heat so much or I did something wrong here? Thanks |
| Yes it is normal for current limiting resistors to get very hot. With a 12v supply, those resistors will be dissipating nearly 11 watts which is all turned into heat. That is also higher than the power rating of the resistors. You generally want a safety margin for the resistors so you would want at least 15 watt resistors. You could eliminate the resistors and all the heat by building the chopper board at the bottom of that page. |
| single axis driver and a b.o.b.,or multi-axis driver board | .xXACEXx. | Stepper Motors and Drives | 3 | 07-02-2007 11:13 PM |
| PMinMo Driver and Interface Board | mymojo | General Electronics Discussion | 0 | 04-26-2007 01:14 AM |
| Question PMinMo Breakout Board | huckshooter | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-21-2005 09:46 AM |
| New and need your help Please (driver board) | Oldmanandhistoy | General Electronics Discussion | 17 | 06-12-2005 04:48 PM |
| driver board | mtaddei | Benchtop Machines | 1 | 11-19-2004 02:13 PM |
