Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 05-18-2008, 05:57 AM
stevestk is on a distinguished road
Stepper power requirements
I'm trying educate myself on stepper motors. I understand the reasoning behind driving the motors at higher voltages than the rating. But doesn't that mean there has to be some current limiting circuitry to keep from frying the motor? On some driver boards, I see that circuitry but often not. Does that mean the driver maker expects it is being handled by the power supply? Example: on Ebay I see a set for sale with a power supply rated at 12V 10A, stepper motors rated at 5.3V 1A, the driver can handle 8-20V 10A. Won't too much current be delvered to the motors without some current limiting adjustment. Nothing is mentioned in the ad.
Old 05-18-2008, 06:33 AM
jalessi's Avatar
jalessi is on a distinguished road
current limiting
Steve,
You are 100 percent correct "There has to be some current limiting"
The less expensive drivers use resistors to limit current.
Be careful purchasing cheap eBay drivers, make sure you read the reviews on the Zone. Several forum members have been scamed.
Also make sure you are looking at the correct driver for your motor a Unipolar driver will not work with a Bipolar stepper motor.
A Bipolar drive with work with both Unipolar and Bipolar.
Jeff...
[IMG] code is Off
Confused about power requirements Curtisbeef Stepper Motors and Drives 11 05-11-2008 12:50 AM
G203V Power Requirements Big John T Gecko Drives 3 10-10-2007 08:54 PM
Stepper Motor Power Requirements GAWnCA Mechanical Calculations/Engineering Design 0 04-07-2007 01:44 PM
2010 power requirements? Splint Servo Drives 1 06-26-2005 08:21 AM
Power Requirements CapnC General Electronics Discussion 4 12-29-2004 10:39 AM
