Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 08-31-2004, 12:34 AM
ACME is on a distinguished road
Question 2A current for 1.25A stepper
can we use 2A current for 1.25A bipolar 4 wire stepper motor?
when my controller box cannot adjust it to lower current, any idea?
my controller(driver box) output current is 2A, my stepper motor is 130oz 1.25A.
or it doesn't matter! we can use 2A for my motor!
thanks
Old 08-31-2004, 02:08 AM
Konstantin's Avatar
Konstantin is on a distinguished road
Use current limiting resistors.
Try Steppercal software.
or compute the values yourself, there is a thread somewhere about that. Or read http://webpages.charter.net/pminmo/OS3unipolardata.pdf.
Also, is your motor 1.25A per phase or total?
Konstantin.
Old 08-31-2004, 03:47 AM
*Registered*
ESjaavik is on a distinguished road
Too little input data.
If your drives are chopper drives, current limiting resistors won't work. The drive will just pour on more voltage to get the dialled in current. And if you choose big enough resistors it runs out of volt, you have lost torque and have a very expensive electric heater.
It may be worth a try to connect resistors in parallel with your windings. That would not limit the current, just convert some of it to heat outside the motor. In theory this should be a resistor with an inductor in series. Without the inductor your high steprate torque will probably suffer. I have never heard about such a connection, and have never tried it myself. So consider any attempt at this as an experiment.
More than this would be guessing, as you don't say what make/type of drive and motor you're talking about.
Old 08-31-2004, 04:18 AM
thanks all,
at the end, i found out my stepper is 2.2A 3.2v nema23 130oz(9.7 kg-cm) bipolar stepper motor not 1.25A,
and driver type is step/direct like A+ A-, B+ B-
sorry for wrong information...
so, that's mean no problem? (over 0.2A)
thanks again and sorry about that
[IMG] code is Off
Stepper motor: voltage vs. current ratings cnczane DIY-CNC Router Table Machines 3 09-08-2008 01:14 PM
Geared Stepper and Current Controll krazycnc Xylotex 3 05-31-2005 11:34 PM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 09:30 PM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 06:58 AM
Stepper motor current alanhunt General Electronics Discussion 3 12-18-2003 10:58 AM
