Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 04-30-2008, 02:44 PM
giggler is on a distinguished road
Shopbot stepper motors do we need closed loop?
I'm considering building a larger router say 8by4 foot and have read that shopbot have been using closed loop stepper motor control.
Have have some pacific science nema 34's and micro stepper drives 6410-006 but the datasheet shows they are not closed loop, like most stepper drives.
I do have a few logic level industrial encoders and want to know is it worth connecting these up to a Gecko G-Rex 100 controller which supports encoder input for step feedback? Is close loop required for the average shopbot sized router, with or without a proper spindle?
When would I see such a benifit using them in closed loop control? I am thinking of rack and pinion drives for x and y while the z will probably be a ball screw. Not sure if that helps?
I understand that in closed loop systems the drives and/or controller monitors the movement for differences and tries to compensate. How often does a shopbot style router require this compensation? (sorry if this is a silly question).
Thanks,
DC
www.tea-with.me.uk
Old 04-30-2008, 05:54 PM
ger21's Avatar
Unless you write you're own control software to do it, the G100 can't do closed loop.
Shopbot sells both closed loop (alpha) and standard models. The closed loop can cut twice as fast. You can buy the closed loop system that the Shopbot uses from Oriental Motor. They are NOT cheap.
But do you need closed loop steppers? A properly designed stepper system should not lose steps. Many machines still sold today use open loop steppers, including the Shopbot Standard, which uses Gecko drives.
For a lot less money, you can build a servo system that will be able to run faster and with higher resolution than a stepper system.
What you choose really depends on what you expect from the machine, and what the machine needs to do what you want it to. Gecko has a FAQ here that gives some direction in regards to choosing steppers or servos for your particular application.
http://www.cnczone.com/forums/showthread.php?t=52090
[IMG] code is Off
Open Loop to Closed Loop Stepper Conversion beamhome Stepper Motors and Drives 9 05-24-2012 02:46 AM
question on closed loop vs open loop (servo systems) boonie Servo Motors and Drives 20 11-09-2007 12:30 PM
Closed-Loop stepper control mmjpotter Stepper Motors and Drives 2 10-09-2006 03:16 PM
Inexpensive Closed-loop Stepper Motor Setup? lazlo Stepper Motors and Drives 4 04-18-2005 09:53 AM
Closed Loop Driver vs. Closed Loop Computer ojibberish Gecko Drives 3 06-08-2004 11:30 AM
